Lack of Boost
Post 776788 by billnbenT5 on 2015-06-25 15:12:24
Sorry chaps I’m back again with more mundane questions. As you could possibly tell from my earlier post about the compressor, I’m a total newbie about all things turbo-istic. I know it’s a B5244T5 engine and I’m led to believe, by GWE, that it’s a 24T turbo. I’ve just been for a quick thrash up the motorway in “Wolfie” and although she’s running well, something seems to be “missing”. I can’t get any more than 8lb of boost. So in reference to the earlier post, do I definitely need a Recirc Valve, or should I be looking at other things first? Your comments would be most appreciated. Brian
Post 776971 by wallace570 on 2015-06-27 12:29:26
use a spray bottle with soapy water on ur boost pipes/intercooler,(like the tyre people do when looking for a punctue) give the car a rev and look for bubbles might be something simple before spending loads of money
Post 776974 by stribo on 2015-06-27 13:11:01
It's a KKK K24 turbo, like above, check for boost leaks.
Post 776978 by dant5r on 2015-06-27 14:50:28
[QUOTE=wallace570;776971]use a spray bottle with soapy water on ur boost pipes/intercooler,(like the tyre people do when looking for a punctue) give the car a rev and look for bubbles might be something simple before spending loads of money[/QUOTE] Unfortunately this will not work as the engine will not produce boost when on a fast idle. You are better off spraying easy start over the boost hoses and seeing if the idle increases.
Post 776992 by Ettienne on 2015-06-27 18:03:03
Def go for the easy start / brake cleaner / wd40 anything flammable. I did that and found leaks in the hoses to the inlet manifold. We replaced them at the southern meet 8 and 10mm silicon 1.5 metres of each iirc and check the one way valves as well
Post 777097 by billnbenT5 on 2015-06-29 06:52:03
Just got back from a weekend away. Thanks for all of the replies chaps, I'll be doing that later on and I'll report back. Brian
