C70 gt T5 low oil pressure warning
Post 778053 by tonyhtb on 2015-07-12 18:34:30
Had a leak on the T5 was the oil return so replaced gaskets slow leak stopped. Had the low pressure light come on dipped the car and only a mm or so from full, any ideas!!??
Post 778054 by stribo on 2015-07-12 18:37:11
If you're lucky it'll be your oil pressure sensor, if not, then it'll be the oil pump.
Post 778057 by tonyhtb on 2015-07-12 18:53:26
[QUOTE=stribo;778054]If you're lucky it'll be your oil pressure sensor, if not, then it'll be the oil pump.[/QUOTE] Thanks!! We're is the sensor located as I'm a Volvo newbie normal fare are W124 Mercs
Post 778058 by claymore on 2015-07-12 19:05:18
sensor is at the front middle of the engine down low. You can just see it above the bottom of the dipstick in this picture. Image
Post 778059 by tonyhtb on 2015-07-12 19:09:51
Thanks!! Nice and easy to get to......maybe not but that's half the fun!!
Post 778064 by tonyhtb on 2015-07-12 19:51:23
So you guys are more experienced with these engines. What's the likelihood of a duff oil pump ? It's got 155000 on the clock full history with detailed oil services every 5000 with 10/40w.
