Anybody used these before?
Post 778879 by Jamest5r on 2015-07-23 08:35:06
http://m.ebay.co.uk/itm/160654832867?_mwBanner=1 Cheaper than getting mine refurbished so wondered if they are any good? Cheers
Post 778881 by stribo on 2015-07-23 08:51:31
Is that where your namesake got his P2 ones from? If so, don't forget to bleed the brakes after fitting them. ;)
Post 778882 by Jamest5r on 2015-07-23 09:13:53
[QUOTE=stribo;778881]Is that where your namesake got his P2 ones from? If so, don't forget to bleed the brakes after fitting them. ;)[/QUOTE] No idea I don't follow his posts but ill be sure to bleed my brakes :)
Post 778883 by t5 pete on 2015-07-23 09:17:25
[QUOTE=stribo;778881]Is that where your namesake got his P2 ones from? If so, don't forget to bleed the brakes after fitting them. ;)[/QUOTE] Pmsl it is confusing hard to tell them Appart. James is it just the outer cv joint ypu need replacing? If so man up and buy a new joint or failing that I'll fit you new ones night before york.
Post 778893 by MoleT-5R on 2015-07-23 14:50:05
[QUOTE=t5 pete;778883]Pmsl it is confusing hard to tell them Appart. James is it just the outer cv joint ypu need replacing? If so man up and buy a new joint or failing that I'll fit you new ones night before york.[/QUOTE] now there's an offer you can't refuse free fitting.......nice one Pete
Post 778904 by t5 pete on 2015-07-23 17:20:38
[QUOTE=MoleT-5R;778893]now there's an offer you can't refuse free fitting.......nice one Pete[/QUOTE] I'm just glad to help don't want james attacking it with the angle grinder lol
Post 778906 by Jamest5r on 2015-07-23 17:27:47
[QUOTE=t5 pete;778904]I'm just glad to help don't want james attacking it with the angle grinder lol[/QUOTE] I'm alright with driveshafts it's just wishbones I struggle with :)
Post 778983 by MoleT-5R on 2015-07-24 06:57:57
[QUOTE=Jamest5r;778906]I'm alright with driveshafts it's just wishbones I struggle with :)[/QUOTE] arrrh wishbones!!! seem to recall 3 members of here trying to fit some to an s60, it was a bit of a fight to get the first to fit. We then found out we'd fitted the wrong side when we went to do the other side. They were a dream to fit when the correct one was used......ooops :cussing:
