Post 779489 by MaxTS on 2015-07-29 09:36:35
Hi welcome to my thread for my 740 2.0 GL manual.
I picked up the car last week with 10 months mot. It's not a minter but it's pretty solid main points are below
Interior is really grubby and a little tatty
Needs a stage zero and cam belt, but I believe it is a non interference engine (?)
Boot doesn't open from the outside so you have to open from the inside.
Weird squeaky sound from what I think it's the fuel pump but it doesn't cause any issues
Fuel gauge doesn't work
Severely knackered inner tie rod which I have the replacements parts for but will probably fit over the weekend
I gave the tank an oil change on Saturday and the old oil was like water :/ also attempted the boot fix but to no avail so I will remove the lock and try to un seize it.
Anyway here's some pictures;
found this is a crevis which someone must have dropped :troutslap
Intake pre heater missing
made a bit of a mess
found this in the boot which had a broken clamp so stuck that back on the rear exhaust which diverted some of the exhaust drone
love that front end of squareness
