double din unit for s70r
Post 779557 by t5 pete on 2015-07-29 17:21:20
Had a look at the sc900 today and some ones all ready been inside it to which I found the cd draw kaput. So onto the double din would the one in the link work with the cars original amp as I know any have had problems with either no sound or crap sound. When I had the v70r that came with a extrons double din which was great but thay had the trouble of the poor sound quality I. E lack of bass or depth. Any help would be much appreciated.
Post 779559 by jamesy12345 on 2015-07-29 17:26:31
no link fella
Post 779561 by t5 pete on 2015-07-29 17:41:27
Opps http://www.ebay.co.uk/itm/double-din-car-gps-dvd-player-sat-nav-800MHz-CPU-Dual-Core-3G-WiFi-DVR-7610MGB-/130841099151?pt=LH_DefaultDomain_3&hash=item1e76bcbb8f
Post 779565 by S70T5Chris on 2015-07-29 18:51:16
That things gonna be a collosal sack of ££££! As long as you get an ISO adapter lead to connect between the factory wiring and the new head unit the sound will be fine.
Post 779566 by t5 pete on 2015-07-29 18:53:09
It looks to have the two rca out puts so should work but would be nice to know if any one else has fitted one
Post 779567 by t5 pete on 2015-07-29 18:55:48
[QUOTE=S70T5Chris;779565]That things gonna be a collosal sack of ££££! As long as you get an ISO adapter lead to connect between the factory wiring and the new head unit the sound will be fine.[/QUOTE] TBH the one that came with the v70r was great Chris sat nav worked perfectly just problems with sound but it didn't have the amp lead to bypass it. I've looked at the better brands for sat nav but at 4 or 5 times the price it's just not worth it thats why I wanted opinions on this from people who have one. This is the lead that the other car didn't have http://www.ebay.co.uk/itm/Volvo-S70-1996-2000-Dolby-Car-Stereo-Amplifier-Bypass-RCA-Harness-Lead-PC9-414-/171728233644?pt=LH_DefaultDomain_3&hash=item27fbcce4ac
Post 780940 by Spooky on 2015-08-08 22:59:45
HIGHLY recommened this one for you Pete http://www.pioneerelectronics.com/PUSA/Car/DVD-Receivers/AVH-X4500BT I have this in mine (after having also got my R with an Xtrons in, replaced it with an Xtrons which went boobies north inside of 6 months). The problem with the cheapo ones i found were the rocker switches they use at the back for the volume/seek/etc buttons were very poor quality. The xtrons ones I had to desolder as they got to the point where the volume would turn it self up full on its own. Bit of heart racer when you're on the M-way i can tell ya! The Pioneer I've had for about 5 months now and cant fault it. I have a modest sub in the boot as well (which is also a Pioneer and was in her when I got her) and the HU drives it well without any amp. The ISO plugs straight onto the car one and it will also dim the HU lights when you turn your headlights on, depending on how you have your dash illumination set. Hope that helps :)
