Post 779901 by JUDGENINJA on 2015-08-01 13:05:47
Rebuilding a turbo looks like a simple bit of plumbing and adjusting.
I see many do it on a table top at home without balancing, but it's one job I've never done, so anyone done a how to (some blue printing measurements etc) or offering to rebuild 2x 18T turbos for me??
Post 779902 by t5 pete on 2015-08-01 13:17:05
There is a good guide on voc for td04 turbos make sure you mark every thing and make sure all the marks line up once rebuilt if you don't want to have it balanced personally I always have them balanced but that's just me
Post 779904 by JUDGENINJA on 2015-08-01 13:38:42
Thanks, who do you use for the balancing?
Post 779905 by t5 pete on 2015-08-01 13:41:13
I just take them to AET to have them balanced
Post 779923 by Tomcat on 2015-08-01 15:05:39
There's a place in Preston Wayne that I used to get mine rebuilt when the rebuild kit I bought online wouldn't fit correctly. They rebuilt it and balanced it for me for about £120 all in. Think they're called Turbo Force or something like that.
Post 779941 by JT on 2015-08-01 16:35:39
I was recommended these guys and had no problems:
Post 779944 by Nealevo on 2015-08-01 17:12:28
I had mine done at ^^^^^^^ too, no probs here.
Post 779967 by Kingsford G on 2015-08-01 20:48:50
Merc85 rebuilt his 18t and by himself as far as I know and was pushing 300bhp
Post 780109 by siamblue on 2015-08-02 23:39:11
I have a few of these here,must have at least 6 of various sizes,i always fancied my hand at rebuilding them,but the balancing kind of put me off.
Post 780110 by Saaamon on 2015-08-02 23:45:32
[QUOTE=JT;779941]I was recommended these guys and had no problems:
[/QUOTE]
Always thought turbo rebuilds would be much more than that..
Post 780120 by M-R-P on 2015-08-03 07:47:11
Costs more than I paid for my K24.
I'll be rebuilding the k24 soon and will be doing a how-to of some kind.
Post 780129 by Ettienne on 2015-08-03 10:16:41
I rebuilt a couple of mine td04's but not k24's
Post 780131 by ExternalError on 2015-08-03 10:38:16
arnt k24s a bit more complex because of the Variable Vanes
Post 780134 by martin_r_smith on 2015-08-03 11:09:33
Do they have variable vanes?
Post 780135 by M-R-P on 2015-08-03 11:11:24
[QUOTE=martin_r_smith;780134]Do they have variable vanes?[/QUOTE]
Not that I'm aware of.
Post 780138 by Ettienne on 2015-08-03 11:21:25
No they don't have variable vanes
Post 780141 by ExternalError on 2015-08-03 11:30:59
yeah sorry my arse and mouth swapped places for a second then
Post 780142 by M-R-P on 2015-08-03 11:52:33
Careful where you put that cheese sandwich then Stu :)
Post 794301 by JUDGENINJA on 2016-01-03 06:58:59
What the deal with the different compressor wheels?
6x6 vane
11 vane
12 vane
Post 794302 by mike 850 on 2016-01-03 07:41:13
It's to do with flow, I think it's 6 for quicker spool, 11 for higher top end flow, not seen 12...
Post 794534 by S40kieran on 2016-01-06 22:28:27
Aren't the cores you buy already balanced
Post 797537 by JUDGENINJA on 2016-02-29 23:00:55
Thought on porting the Turbo exhaust housing and exhaust manifold before reassembly?
Post 797542 by MoleT-5R on 2016-03-01 01:46:11
[QUOTE=JUDGENINJA;797537]Thought on porting the Turbo exhaust housing and exhaust manifold before reassembly?[/QUOTE]
been looking at the angled flange I have here, but don't want to open it up, as I worry this could effect the way the gases reach the turbine wheel. but I'm all for a bit of smoothing and polishing to cut down on any turbulence on the way to the turbine that could in any way possibly restrict the exhaust gas flow.
Post 797565 by JT on 2016-03-01 19:17:08
Turbo Rebuild will say its not worth it, the gains are too small.
Post 797577 by MoleT-5R on 2016-03-01 23:43:57
[QUOTE=JT;797565]Turbo Rebuild will say its not worth it, the gains are too small.[/QUOTE]
shirley a gain is a gain.....lol, but to small for them to charge for possibly, still looking at it, but I wouldn't spend too much time on it.
Post 797578 by JUDGENINJA on 2016-03-02 00:10:05
My thoughts at that there is a ridge like a humped back whale that can be taken out of the way. Also another (yes I've been watching Americans on YouTube) is to open the waste gate hole a bit..
Just found a s/hand die grinder a eBay... So I'm going to give it a go.
Watch this space (probably for tears).....
Also I'm limited to ~1.1bar due to my boost limit at the moment, so need to maximise flow where possible.
