Fewjobs
Post 780416 by Dannyboy7 on 2015-08-05 09:13:09
One of the things I have to look at or change is the washer bottle which is showing a fault light. Do I need to buy a new sender or is it not separate from the bottle itself? Plus I'm changing a lens on one if the headlights as well so is it best to remove the front bumper? Thanks Dan
Post 780429 by c70geoff on 2015-08-05 11:37:11
u can change the lens without having to remove bumper as for the washer bottle ive not come across that faut yet but sure someone has
Post 780452 by Biff on 2015-08-05 14:36:17
Going off my old v70R awd (1998) I removed mine by taking off the black undertray & managed to get my skinny arms up to unbolt it but it wasn't easy & if your a fella with a bit of girth I reckon you may struggle. A set of ratchet spanners would certainly be your friends!
Post 780454 by jamesy12345 on 2015-08-05 14:43:11
A bit of info here http://www.volvoforums.org.uk/showthread.php?t=49757 http://www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=22993 (assuming they are the same between 850's and P80 cars)
Post 780552 by Dannyboy7 on 2015-08-05 22:27:48
Hi thanks for the great info will give it a go.
