Unusual Tyre Wear - Rear Right
Post 780825 by TenaciousC on 2015-08-08 12:02:09
Hi All, Anyone care to suggest why I might be getting inner and outer shoulder wear on one tyre only (rear right) ? It's an estate with Nivomats. Pressure is 33 PSI. It's been 4 wheel laser tracked last year in October. I can't sense any handling issues all seems as normal. Thanks for any ideas. C
Post 780827 by jamesy12345 on 2015-08-08 12:11:50
Shoulder wear usually means under inflation, but 33 psi sounds OK for an unloaded car. For heavy loads or hard cornering maybe try upping the pressure a little. http://www.carbibles.com/tyre_bible_pg3.html
Post 780830 by TenaciousC on 2015-08-08 12:30:48
[QUOTE=jamesy12345;780827]Shoulder wear usually means under inflation, but 33 psi sounds OK for an unloaded car. For heavy loads or hard cornering maybe try upping the pressure a little. http://www.carbibles.com/tyre_bible_pg3.html[/QUOTE] Yes, it looks like classic under inflation... though the pressure says otherwise. I've just done a crude test of the track, by putting a straight 5ft pole against the tyre and measuring the distance from the sill and the end of the pole. On the worn side it's about 3/4 inch and on the OK side it's 1.5 inch. Looks like they're not quite pointing in the same direction (assuming the sills are not bent)! Assuming the left wheel is aligned correctly... a bit of trigonometry tells me the right one is 0.62 degrees different and the range is supposed to be -0.11 to 0.25 degrees. Is the toe adjustable on the rear suspension? C
Post 780832 by jamesy12345 on 2015-08-08 13:02:32
[QUOTE=TenaciousC;780830]Yes, it looks like classic under inflation... though the pressure says otherwise. I've just done a crude test of the track, by putting a straight 5ft pole against the tyre and measuring the distance from the sill and the end of the pole. On the worn side it's about 3/4 inch and on the OK side it's 1.5 inch. Looks like they're not quite pointing in the same direction (assuming the sills are not bent)! Is the toe adjustable on the rear suspension? C[/QUOTE] I could be wrong but seems that one side toe out is about 0.7 degrees & the other is 1.4 degrees? that would have shown up in the laser alignment if it was out angle = sin^-1 (19/1524) [ATTACH=CONFIG]29405[/ATTACH] //edit some values in the link below, and a section on adjusting rear toe https://www.volvoclub.org.uk/tech/service/850/WheelAlignmentSpecificationsProcedures.pdf
Post 780838 by M-R-P on 2015-08-08 14:43:51
Get it aligned on a hunter system. Most alignment places will just align the front wheels to the rears and that's no good for Volvos. They need to be aligned independently.
Post 780842 by Nealevo on 2015-08-08 14:55:50
As above, get it done on a good machine, not sure of newer models but my 850, all wheels can be independently aligned.
Post 780845 by M-R-P on 2015-08-08 15:14:02
[QUOTE=Nealevo;780842]As above, get it done on a good machine, not sure of newer models but my 850, all wheels can be independently aligned.[/QUOTE] Even more adjustments on p2 iirc
Post 781003 by Saaamon on 2015-08-09 14:28:20
As said really need to have it done on a hunter system and with that you'll get a before and after print out, then you know its actually been done!
Post 781041 by sunny scott on 2015-08-09 19:33:15
Excuse my Ignorance here as only new and never knew about the Hunter system, Do Volvo use this for alignment? any Scottish guys on here know who has this system? just in case I need it in the future.
Post 781074 by jamesy12345 on 2015-08-09 21:16:36
[QUOTE=sunny scott;781041]Excuse my Ignorance here as only new and never knew about the Hunter system, Do Volvo use this for alignment? any Scottish guys on here know who has this system? just in case I need it in the future.[/QUOTE] Google says.. http://www.pro-grip.org.uk/index.html nr Falkirk http://www.mtekbmw.com/index.asp?key=9 Rutherglen
Post 781078 by stephenevans99 on 2015-08-09 21:27:21
Had mine on a Hunter system a few weeks back, a very impressive system and not expensive either.... Image Image Mine was done by DP Tyres in Wigan
