C70 awd ??????
Post 781349 by SebiT5 on 2015-08-11 20:30:38
Hi did any one know someone who ever try mod a C70 from FWD to AWD ? As Im thinking to do that on my T5 :confused:
Post 781384 by Biff on 2015-08-11 22:34:43
I wouldn't bother. The cost would outweigh the unreliable outcome. Awd is a mine field of engineering part changes & not the best of designs. I absolutely hated working on my v70r awd in the end. Nothing is easy & everything will break unless you get an absolutely mint doner car which I doubt. Ring Volvo parts dept for prices & prepare for a new shade of poo.
Post 781386 by Ettienne on 2015-08-11 23:02:17
Buy a Subaru it will be much cheaper
Post 781393 by Saaamon on 2015-08-12 00:24:31
Someone done it to a 854R. Not sure where the thread is but think its on T5D5.
Post 781395 by stribo on 2015-08-12 01:02:07
I've looked into it, and the engineering involved is just a nightmare. The AWD uses a totally different rear suspension, which use mounting points that aren't on a standard 850/x70 floorpan. The AWD rear suspension is so overly complicated, it's bordering on laughable. Also the rear brakes (discs, and calipers need changing. IMO, it would be easier to weld a C70 body to a 850/V70 AWD floorpan. All that having been said, if you're determined enough, and have the skills, or lots of money, it is possible. ;)
Post 781400 by SebiT5 on 2015-08-12 06:43:19
[QUOTE=Ettienne;781386]Buy a Subaru it will be much cheaper[/QUOTE] Too slow mate...
Post 781401 by SebiT5 on 2015-08-12 06:47:01
[QUOTE=stribo;781395]I've looked into it, and the engineering involved is just a nightmare. The AWD uses a totally different rear suspension, which use mounting points that aren't on a standard 850/x70 floorpan. The AWD rear suspension is so overly complicated, it's bordering on laughable. Also the rear brakes (discs, and calipers need changing. IMO, it would be easier to weld a C70 body to a 850/V70 AWD floorpan. All that having been said, if you're determined enough, and have the skills, or lots of money, it is possible. ;)[/QUOTE] Thx STRIBO...was asking cos my car will have a bit of power and Im not so sure if standard axles will handle it...
Post 781406 by jamesy12345 on 2015-08-12 07:32:56
[QUOTE=SebiT5;781349]Hi did any one know someone who ever try mod a C70 from FWD to AWD ? As Im thinking to do that on my T5 :confused:[/QUOTE] Just buy one of these mate & get it shipped home from Lagos.... https://www.cheki.com.ng/vehicles/1999-volvo-s70-lagos-nigeria-a313228.html?click_source=car_title&page_number=1&position_number=1 (S70 AWD was produced but not sold in UK) This is the guy who made an 850R AWD, St Petersburg (Russia) plates on it https://www.drive2.ru/r/volvo/4062246863888392403/
Post 781412 by p fandango on 2015-08-12 09:29:20
As said, it's been done a few times with 854's. & a C70 is just an 850 in a skirt
Post 781414 by Jamest5r on 2015-08-12 09:48:22
It's been done in Australia https://ozvolvo.org/discussion/329/rob-s-c70-t5-awd/p1
Post 781416 by Doingitsideways on 2015-08-12 11:20:28
Doesn't the C70 have a wider rear track, or am I talking out of my arse? Would mean longer driveshafts as well as welding in a million mounting points for the subframe, probably extending that too. Now, a RWD C70 would be awesome. Turn the engine round and bolt an M90 to it. Lovely :)
Post 781420 by SebiT5 on 2015-08-12 13:01:05
[QUOTE=Doingitsideways;781416]Doesn't the C70 have a wider rear track, or am I talking out of my arse? Would mean longer driveshafts as well as welding in a million mounting points for the subframe, probably extending that too. Now, a RWD C70 would be awesome. Turn the engine round and bolt an M90 to it. Lovely :)[/QUOTE] Seen one of the c70 RWD with merc AMG diff conversion was awesome
Post 781421 by SebiT5 on 2015-08-12 13:02:06
[QUOTE=Jamest5r;781414]It's been done in Australia https://ozvolvo.org/discussion/329/rob-s-c70-t5-awd/p1[/QUOTE] Thanks mate for a link will go through it and see if its worth it
Post 781422 by SebiT5 on 2015-08-12 13:04:47
[QUOTE=jamesy12345;781406]Just buy one of these mate & get it shipped home from Lagos.... https://www.cheki.com.ng/vehicles/1999-volvo-s70-lagos-nigeria-a313228.html?click_source=car_title&page_number=1&position_number=1 (S70 AWD was produced but not sold in UK) This is the guy who made an 850R AWD, St Petersburg (Russia) plates on it https://www.drive2.ru/r/volvo/4062246863888392403/[/QUOTE] Thanks mate for info need to know as much as possible before I'll start the project cos its easy to f... things up .
Post 781433 by Saaamon on 2015-08-12 14:45:30
It's not uncommon in the ford world for people to weld Sierra and Escort floorplans and bulkheads to FWD cars. If you had the skill set I'm sure it could be done with a Volvo.
Post 781434 by Saaamon on 2015-08-12 14:48:24
http://forums.t5d5.org/topic/15067-volvo-850r-awd-saloon/ Here's the one I was referring to.
Post 781439 by Doingitsideways on 2015-08-12 15:11:57
Also increasingly common for them to be using redblocks and T5 lumps
Post 781449 by p fandango on 2015-08-12 17:17:02
[QUOTE=Doingitsideways;781416]Doesn't the C70 have a wider rear track, or am I talking out of my arse? Would mean longer driveshafts as well as welding in a million mounting points for the subframe, probably extending that too. Now, a RWD C70 would be awesome. Turn the engine round and bolt an M90 to it. Lovely :)[/QUOTE] The rear axle is about 5mm wider, but the factory a me will have to be binned anyway to fit the awd one (which is based on a 700/900 rear axle)
Post 782876 by AshDVS on 2015-08-23 08:17:38
One of the guys on the OzVolvo forum built a C70T5 AWD manual using mostly donor parts from a V70XC.
Post 782954 by Jamest5r on 2015-08-23 18:15:50
[QUOTE=AshDVS;782876]One of the guys on the OzVolvo forum built a C70T5 AWD manual using mostly donor parts from a V70XC.[/QUOTE] See post 10 Ash :)
