Replacement keys 850
Post 781872 by Ettienne on 2015-08-16 00:36:36
I've found a couple of places which do replacement keys on line and there's a couple of shops locally. When are people doing about replacement keys? With or without transponders I've found a place online that will cut from the key code or photo (if photo they then supply code to you) and will reprogramme a transponder if original key supplied.
Post 781898 by Ettienne on 2015-08-16 11:22:15
Found a local shop not too bad in price
Post 781900 by jamesy12345 on 2015-08-16 11:54:55
I used the company below to find a key blank for an old Renault door key + cut it according to a code I gave them http://www.keytrader.co.uk/ ...& a Timpson's to cut a Honda ignition key. Neither of the keys were transponder type.
Post 782126 by p fandango on 2015-08-17 11:50:09
Volvo only charged me £9.40 for a replacement laser cut key (non-transducer), that was back in 1999 so they might of changed
Post 782127 by MaxTS on 2015-08-17 11:54:05
Steve, where is this place? I only have one key for my R :(
Post 782156 by Ettienne on 2015-08-17 19:04:43
Cascades opposite fabric land £12 supplied and cut, I thought it wasn't unreasonable (non transponder) or £40 transponder. I've found a place that does transponders for £25 (online you'd have to send your key) Timpsons wouldn't touch it as no blank and would want £25 if they did for non transponder
