signature pic doesnt show?
Post 782047 by Tee5alive on 2015-08-16 21:40:03
uploaded pic- shows now in settings but not on the forums?? I have the check boes ticked to allows images wassup please?
Post 782072 by Dangerous Dave on 2015-08-16 22:56:58
Will look into this for you bud. Please bear with us :)
Post 782073 by jamesy12345 on 2015-08-16 22:57:23
I can't see your signature pic either. Maybe the file is too big? Try linking it from Photobucket or similar, like mine below [ATTACH=CONFIG]29458[/ATTACH]
Post 782091 by Dangerous Dave on 2015-08-17 00:52:13
It seems your signature is not enabled by default (under the 'Quick Reply' box there should be a check box for 'Show your signature' if it is unchecked then your signature will not show) I have edited your post to test this and your signature was not set to show. You can change the global setting by going to the 'Settings' button on your member navbar at the top of this page, then on the left hand menu go to 'General Settings'. Half way down that page under 'Thread Display Options' there should be an option to 'Show Signatures'. Check this box to always post your signature. Hope this helps
Post 782094 by Tee5alive on 2015-08-17 07:07:47
Thanks all HMMM just had a look and all the boxes are checked :( UPDATE : brain firing on all 5 tonight all sussed DUUUH!!
Post 782216 by Dangerous Dave on 2015-08-17 23:50:17
No worries, what was it in the end?
Post 782221 by Doingitsideways on 2015-08-18 00:09:28
Test running mine too, don't mind me :) Edit: Yay :D
Post 782226 by Tee5alive on 2015-08-18 06:53:39
I copied and pasted the image details INTO an HTML link and WHAMMO!! done
