Post 782935 by Blackdog on 2015-08-23 17:18:33
Anyone know what 00bc is?
According to the list here (although for a P2) its an SRS fault code http://forums.t5d5.org/topic/9490-list-of-error-codes-and-descriptions-for-phase-2-cars/
Thanks, but not sure on that one. Car went into limp mode with an engine system maintenance required message thown up on the dash.
http://www.cardiagnostics.be/-now/VOLVO%20VIDA%20VADIS_bestanden/PPC-VOLVO_Manual.pdf Theses are volvo codes
Says the same thing, SRS code, rear left impact sensor.
Do those codes apply to a 2014 MY V70? The text on BSR says not for S80 2007 onwards. I can't see that an SRS impact sensor would put the engine into limp mode.
I would think it would say srs service ASAP ,not engine limp but you never know.
Turns out it is a MAF sensor fault code. It was recorded as intermittent so a clean of the contacts by Volvo and see what happens. Just a PITA it happened on the way to holiday so no car for one and a half days until a renter was supplied by Volvo Assist. Nice Fiat 500 large.... It was the only thing in the area big enough to fit the dogs in the back of.
[QUOTE=Blackdog;783159]Turns out it is a MAF sensor fault code. It was recorded as intermittent so a clean of the contacts by Volvo and see what happens. Just a PITA it happened on the way to holiday so no car for one and a half days until a renter was supplied by Volvo Assist. Nice Fiat 500 large.... It was the only thing in the area big enough to fit the dogs in the back of.[/QUOTE] Would be good to get a code list for the later cars by the sounds of it. Glad you got it sorted bud :) fingers crossed it will behave for you :D
