i might be being thick here,but!
Post 61184 by TEAMWAYSIDE21 on 2005-11-30 08:47:42
can i take off my volvo battery on my 850 t5 1994 estate,without it knackering all the radio codes(original radio) or doing something else??? answers on a postcard please!
Post 61186 by The Flying Banana on 2005-11-30 08:51:09
Easy way is to buy a memory saver box that most auto stores should have, just clips on your terminals and when you disconnect battery it keeps enough in it to save codes etc. If you are a cheapskate tho just connect a cuppla jump leads to it from another car or a booster pack ...change batteries and viola!!!
Post 61213 by Goof on 2005-11-30 10:58:19
Your local Volvo dealer will be able to supply the radio code (mine did it over the phone - but they know the car & me). That's assuming it is the original radio. Failing that, jump a spare 12V battery onto the connectors before disconnecting.
Post 61382 by Gulty on 2005-12-01 07:45:01
Round here its £20 to get it unlocked, plus they give you the code. Takes a day or two if you can live without stereo Gulty
Post 61415 by Wobbly Dave on 2005-12-01 10:00:46
Start the car - remove battery - put in new battery - job finished.
Post 61427 by madness on 2005-12-01 10:41:47
pm me your reg no and i will give you the code
Post 61449 by TEAMWAYSIDE21 on 2005-12-01 13:23:24
pm sent
Post 61501 by madness on 2005-12-01 16:01:07
code sent on pm.
