tyres on volvo v70r 18" pegasus wheels
Post 785254 by Craigtange on 2015-09-09 09:50:42
Hi there again folks just a quick one, what size of tyres and make are people running on these wheels, currently have 234/40/r18 can you put on a 225 without issues or better to stick to the 235? cheers
Post 785257 by stribo on 2015-09-09 10:07:34
You could fit 225s, but why would you want to? We've stuck to 235/40/18s, but toying with the idea of spacers and 245/40/18s or 245/35/18s.
Post 785264 by Craigtange on 2015-09-09 10:49:25
Mmmm, interesting. never thought about it in that way. i will need to look into this further :) cheers
Post 785267 by stephenevans99 on 2015-09-09 11:12:13
Do 235s not rub when on lock? 225's sound a more sensible size tbh
Post 785270 by Ettienne on 2015-09-09 11:23:46
I didn't have spacers And had 245/40/18s They were listed with 225/40/18s in US iirc but I use 235/40/18s when putting tyres on.
Post 785272 by stephenevans99 on 2015-09-09 11:28:13
[QUOTE=stephenevans99;785267]Do 235s not rub when on lock? 225's sound a more sensible size tbh[/QUOTE] I assumed they were going on the Saffy....for a P2 V70R then 235s are spot on
Post 785276 by stribo on 2015-09-09 12:09:30
[QUOTE=stephenevans99;785272]I assumed they were going on the Saffy....for a P2 V70R then 235s are spot on[/QUOTE] I guessed they were going on a P2, as it's in the P2 section, but yes, 235s would be to wide for a P1 V70R.
Post 785279 by Harvey on 2015-09-09 12:35:05
Down to tyre choice I guess it depends how much you use it. Summer tyres or a good all weather one's or winters. As you do get it colder than us down south.
Post 785284 by Craigtange on 2015-09-09 13:19:31
yeah, i bought a set of winter/snow tyres 2 years ago and since then i have had no snow up here...sods law but not complaining. i have 345's on just now with no rubbing so i will just go with that tyre size.probably a half decent set of all weather ones.
Post 785285 by Craigtange on 2015-09-09 13:20:48
[QUOTE=stribo;785276]I guessed they were going on a P2, as it's in the P2 section, but yes, 235s would be to wide for a P1 V70R.[/QUOTE] yeah i dont have that saffy anymore but cant figure out how to change the picture.
Post 788711 by chris54321 on 2015-10-18 13:55:36
I run 235s on my P2 V70R, and have to say the type of tyre compound is more important than the contact surface, when I bought the car, you could spin the wheels in 3rd they were so hard, and in the end I had to change all 4 for new grippier ones just to keep it glued to the road, now runs great. I have noticed that with my car on full lock they just touch on one side of the inner plastic trim, but as you are only travelling slow it is not a problem. Good luck with the choices available, and the budget you will need.
Post 788810 by Redbrick on 2015-10-19 00:02:02
Assuming P2, 235/40 18 Vredestein Ultrac Vorti are very good.
