BBS Nebula Alloys
Post 786105 by NECC on 2015-09-18 21:42:53
Will these a straight fit on to a 1999 V70, or will i need spigot rings and spacers ??? And if they fit whats the best width tyres to use please ??? Cheers Shaun
Post 786111 by AcidicDavey on 2015-09-18 22:07:27
You might need spacers on the rear as your car is an AWD. Infact, you might need some on the front too or else you'll be rubbing on lock. Here's a handy calculator for figuring out clearance differences between 2 different wheels. http://www.willtheyfit.com/index.php?width=215&aspect=45&diameter=1&wheelwidth=7.5&offset=43&width2=215&aspect2=35&diameter2=18&wheelwidth2=8&offset2=49#content When I had P2 wheels on mine I had 7.5J rims and a wheel weight caught on an arm, Nebs are 8J with the same +49 offset so you'll have even less inner clearance. I'd recommend 10-15mm spacers. You don't need spigot rings as they have the same centre bore on P2 cars. Tyres - 215/35/18
Post 786112 by Nealevo on 2015-09-18 22:07:56
Straight fit, may need a small spacer on rear look for 215 or 225 tyre
Post 786121 by The Flying Moose on 2015-09-18 23:31:58
Second the above comments, I would definitely go for a 215/40 tyre profile however.
Post 786123 by AcidicDavey on 2015-09-18 23:56:14
You're probably right there Moosey boy, the ride in my car isn't great with 215/35/18s but saying that it is better than the 205/40/17s that were on before!
Post 786166 by NECC on 2015-09-19 21:19:08
Thank you guys
