V70 T5 boost problem
Post 786514 by Mart5in on 2015-09-22 18:34:07
Hi I'm Martin! Bought myself a V70 T5, had some issues with it, stupidly got it mapped to 310hp and of course the problems are still there! :D
Anyways, I've had codes pulled for faulty throttle pedal. removed the connector and reconnected it and they haven't been back for months, although sometimes the cruise control still disables itself as soon as I take my foot off the throttle after setting a speed.
Under load, the car appears fine but it seems to hesistate in the higher rpms and just generally feels a bit down on power especially when trying to hold boost for long periods of time (as you can see from my avatar I do plan on more track days), it's very intermittent.
It's got everyones favourite throttle body on it too, although I noticed that there appears to be a white dot painted on the TPS. Not sure if this has maybe been repaired in the past?
Okay, so the most current "faults" I've had where a code has been triggered. I can only pull generic P codes. I've had boost flow too low, boost flow too high, (not at the same time of course!) long term fuel trim lower limit - I think this last one is probably due to the fact my exhaust isn't in the best of condition. I can't remember the codes but that was the descriptions I have.
So, what I'm asking is, does this point at the MAF? I replaced it with an eBay cheapo. If I disconnect the MAF the car is slower but it boosts consistently slower - of course the idle is all over the place with that unplugged.
Anything else I could check? Boost solenoid and it's pipes? What size of pipe do I need if I change them to silicone?
Do you think my boost and stuttering is a combination of throttle pedal, boost solenoid and cheap MAF?
Thanks in advance
Martin
Post 786529 by Shinsplintz 101 on 2015-09-22 19:41:56
Stuttering is often down to the ignition system breaking down under load. Check the plugs etc.. & replace anything that you're unsure about.
Boost wise I'd definitely replace the tcv & redo the vac hoses checking for leaks/tears/holes on the main boost pipework from the turbo to ic & back to the tb.
Depends on the history you have with the car as to when items have been replaced in the past , better safe than sorry so if unsure get a good used part or new OE one.
Good luck. Morgan
PS vac hoses are 4mm id, one is 6mm. Use good quality fuel hose, cheap & very effective.
Pps get a good known OE maf & swap it in , that'll give you an idea if your cheap eBay special is faulty.
Post 786531 by stribo on 2015-09-22 19:51:46
Hesitation at higher revs could point to a VVT problem, but as above, check plugs and coilpacks first.
Post 786565 by Mart5in on 2015-09-22 23:21:29
Thanks for the replies so far!
I've had one of the coil packs changed and all of the spark plugs done a while back. The plugs were totally goosed.
I'll get some hose ordered up, I actually think I have some 6mm in the shed!
I'm gonna step away from the VVT suggestion :haha: I've no reason to suspect it unless it's a freak failure. The car has never missed an oil change so no sludge build up etc. lowish miles too. I will keep it in mind. :)
So what I really need is a known good MAF. What MAF's from other models will fit? There's a few down the local scrapyard I could rob bits off. (2.4 lpt and a bi fuel) and I'm sure there's a couple of S80's in there too but I don't know what engines are in them.
Post 786572 by stribo on 2015-09-23 00:14:40
[QUOTE=Mart5in;786565]Thanks for the replies so far!
[COLOR="#FF0000"]I'm gonna step away from the VVT suggestion :haha: I've no reason to suspect it unless it's a freak failure. The car has never missed an oil change so no sludge build up etc. lowish miles too. I will keep it in mind. :)[/COLOR]
So what I really need is a known good MAF. What MAF's from other models will fit? There's a few down the local scrapyard I could rob bits off. (2.4 lpt and a bi fuel) and I'm sure there's a couple of S80's in there too but I don't know what engines are in them.[/QUOTE]
Why would you call it a freak failure, the reason I suggested it was because we had the same symptoms with our S60R, also full service history, using better oil than your T5 would have seen. If it's been sat up for a while the solenoid could have seized, or the VVT unit itself. But as said before there are other things to check before the VVT. Also if the VVT was playing up you would get a code, even on a generic reader.
Post 786577 by Craigtange on 2015-09-23 07:50:34
Are the hoses from the TCV all 6mm? Looking to replace all mine also.
cheers.
Post 786583 by Shinsplintz 101 on 2015-09-23 11:26:28
No just the 1 iirc, the others are 4mm id.
Post 786586 by mike 850 on 2015-09-23 12:18:33
definitely try a know good maf not a ebay special
Post 786588 by Craigtange on 2015-09-23 12:37:59
[QUOTE=Shinsplintz 101;786583]No just the 1 iirc, the others are 4mm id.[/QUOTE]
silly question, what is the iirc, this is on a v70 r 2005.i thought it was all 6mm hoses from the TCV typical i just ordered 6mm ones. :confused:
Post 786608 by M-R-P on 2015-09-23 15:11:15
I hesitation at high revs and boost could be the engine protecting itself from overboost or lean running (as well as the above possibilities).
A dirty maf can give a throttle position sensor code - don't know why but it can.
It wouldn't hurt to clean or replace the boost pressure sensor as that can cause issues with boost.
What injectors are you running? What condition are they in? If they're not up to the job you'll be running lean.
Post 786619 by Shinsplintz 101 on 2015-09-23 18:35:00
Iirc- if I recall correctly.
Best way is just to measure the existing pipework, then order the same size. The p2 may well be all 6mm, for some reason I thought the p2 vac tubing was the same size as the p1. Happy to stand corrected. Cheers
Post 786620 by Dream3r on 2015-09-23 18:39:17
5mm ID some of it is.
Post 786674 by M-R-P on 2015-09-23 23:39:20
It's all 5mn apart from the recirc which is 4mm.
The bigger pipes (evap and brake servo) are 9mn I/d
Post 786913 by Mart5in on 2015-09-26 19:06:29
Ahh well, I've no VVT codes.
However today I got a P0101.
Think I'll just chuck my cheap MAF sensor out and get a good OEM one ordered. :)
Post 786916 by Dream3r on 2015-09-26 19:27:09
Go for Bosch OEM maf, also check for leaks everywhere that code can be misleading.
Logging the maf will show you if it at fault.
Post 786953 by Mart5in on 2015-09-27 09:57:31
[QUOTE=Dream3r;786916]Go for Bosch OEM maf, also check for leaks everywhere that code can be misleading.
Logging the maf will show you if it at fault.[/QUOTE]
Yeah I know it won't :)
My friend has bought a 2.3t 850, is the maf the same on that I could use that to diagnose it since it's known working and genuine volvo.
Is it best to go to Volvo for the OEM maf? or is there another place I can get a genuine MAF? I don't trust ebay for genuine stuff, sometimes it's hard to tell.
Post 786954 by Dream3r on 2015-09-27 10:10:25
Volvo i'd price against these guys then make your mind p, remember you get discount @ FRF Volvo wit the code C5 http://www.emissioncontrols.co.uk/page.php?domain_name=emissioncontrols.co.uk&viewpage=Maf%20%20Sensors
IIRC Volvo will be more expensive as they sell the housing and the sensor as once piece..
Post 786955 by Mart5in on 2015-09-27 10:24:27
[QUOTE=Dream3r;786954]Volvo i'd price against these guys then make your mind p, remember you get discount @ FRF Volvo wit the code C5 http://www.emissioncontrols.co.uk/page.php?domain_name=emissioncontrols.co.uk&viewpage=Maf%20%20Sensors
IIRC Volvo will be more expensive as they sell the housing and the sensor as once piece..[/QUOTE]
Thanks, I'll drop them an email.
I'll check EuroCarFarts and see if they have them as well - convenience factor as they're right next to my work.
Yeah I forgot that they sell the whole housing and not just the sensor. How much can they charge for a plastic tube I wonder!
The more I think about the MAF the more it makes sense. I can read the flow rate off it but I'm not sure if my reader will react fast enough. I might go log some data and plot it on a graph. see what it looks like.
Post 786956 by Bones on 2015-09-27 10:25:36
When nine was stuttering it was a dodgy Maf, kept throwing a code every now and again but most of the time it was fine, try giving it some stick and it felt like someone was shaking you by the back of the neck!
New Bosch Maf and all sorted!
I did all my hoses aswell, 4mm and 8mm is what I ordered. So now they're all blue and match in with the IPD intake and intercooler pipes.
Post 786990 by Redbrick on 2015-09-27 22:40:57
Cheapest place I could find a genuine Bosch MAF was buycarparts.co.uk
Based in Germany and no issues with payment if you use Paypal, Credit card required a photo of the actual card hence why I used papal on the next order.
If you hold it in the basket you get a discount code via Email ;)
Post 789616 by Mart5in on 2015-10-30 17:27:53
Okay, well I've got a contactless tps sensor to fit. (that's pretty much all I've got left) it's been dropping out of cruise control etc as well.
Any threads with pics? Just for a bit of guidance before I look and see what I need to get the throttle body off.
any snags? Looks like 4 bolts after you get the boost pipe off.
Post 789642 by M-R-P on 2015-10-30 19:54:23
That's about it.
Be careful with the spanners tho, the live terminal on the starter motor is very nearby and it's always live.
Post 789664 by Mart5in on 2015-10-31 01:05:34
[QUOTE=M-R-P;789642]That's about it.
Be careful with the spanners tho, the live terminal on the starter motor is very nearby and it's always live.[/QUOTE]
That's why you disconnect the battery before doing major work on the car ;)
Can I just say, what an absolute count of a job that was fitting the contactless tps to the ETM. Definitely do not recommend doing this DIY. Scraping the horrible hard glue out was the hardest part - ended up using a sharpened screwdriver.
If I ever have to get it changed on a future Volvo, I'll be paying someone to do it for me hahahha!
I'll fit the ETM tomorrow after the sealant has fully cured and post up the results.
Post 789755 by Mart5in on 2015-11-01 01:25:31
This is now fixed!
The contactless TPS has cured all the running issues apart from one. I've got a rough idle/misfire first thing when cold (lasts only a minute or so)
No hesitation, no jerkiness, no cruise control drop-out, able to hold boost without fluctuations :)
In case anyone wants to know, I didn't disconnect the battery, I covered the started motor live with a cloth. As soon as I fitted the throttle body, started the car and it was immediately ok. No need for it to "learn" or anything.
Post 790187 by Mart5in on 2015-11-07 00:30:17
Right, I'm back again.
Cruise control no longer works, it drops out if it does work, "Engine system service urgent" and "engine system service required" show on the display.
There was a code stored P1172 but I wiped that and the 2 messages are back again within about 5 minutes.
No EML is lit.
Sometimes there is no/low boost - the rest of the time it appears fine. all the boost pipes are in good condition, there are no splits or leaks. I've checked all the unions and clips :)
Not sure if this is related, but when I first got the car I could quite easily manage 28-30mpg and now over the same journey I'm only getting 24-25mpg.
any ideas would be appreciated!
