compression figures on a cold engine
Post 786711 by mike 850 on 2015-09-24 18:03:03
anyone done this, i know your supposed to do it on a warm engine and the figures will be lower but just seeing what people get, just did might and it was about 102psi on all 5 no difference in any which i think is what i need to look out for?
Post 786714 by Ettienne on 2015-09-24 18:58:10
Mine have always been 160-175, obviously all plugs out and full throttle when cranking on a good battery
Post 786716 by stribo on 2015-09-24 19:04:34
Obviously you want the same sort of figure across all the cylinders, from what I've read your looking for 150+, but not sure if that's on a cold engine, and whether or not you should do that dry, or with oil in. I'm sure someone who knows more than me (not difficult) will be able to advise the correct procedure. :)
Post 786717 by mike 850 on 2015-09-24 19:08:02
just warmed in up and it was still 100 but noticed the cheap pos tester i just bought seemed loose on the snap on connector, put some tape on it and got 125 but think its still leaking, just jbwelding the mofo and will try again
Post 786721 by oblark on 2015-09-24 19:26:05
!50+ psi would be on a warm/hot engine with no oil in the bores, You would only add oil if you had low readings and the oil would confirm if the low compression was rings or valves. A cold engine engine should be 100+ psi
Post 786733 by mike 850 on 2015-09-24 20:34:22
Well added oil and readings went up to 175, don't know why as I had the bottom end checked out before having the rods fitted about 2k ago, bugger
Post 786792 by Ettienne on 2015-09-25 10:13:22
[QUOTE=oblark;786721]!50+ psi would be on a warm/hot engine with no oil in the bores, You would only add oil if you had low readings and the oil would confirm if the low compression was rings or valves. A cold engine engine should be 100+ psi[/QUOTE] My engine we changed, had 140, 150, 165, 165, 170 cold it sounded good and ran fine but 150 iirc is the tolerance and we had to take box out. The new one cranked over 160 cold, but that had been sitting 7 years, I should do a comp check again now it's up and running.
Post 786796 by oblark on 2015-09-25 10:56:58
The me7 engine I had from you cranked over cold at 120 psi across all cylinders.
Post 786798 by mike 850 on 2015-09-25 11:10:53
Well, spoke to the guy who fitted the rods, he thinks a hone and new rings will sort (i thought he honed before but it was just a clean) any ideas of the best place to get rings from, i hear Volvo dont do them anymore? Im assuming that because adding oil and the results dramically change the testing equipment is ok and it is the rings
Post 786806 by oblark on 2015-09-25 12:34:38
Jamie at partsforvolvo
Post 786818 by mike 850 on 2015-09-25 14:07:19
Cheers mate, are they what you are using?
Post 786819 by Ettienne on 2015-09-25 14:11:56
[QUOTE=oblark;786796]The me7 engine I had from you cranked over cold at 120 psi across all cylinders.[/QUOTE] I had mine on the booster pack as well so may spin a bit faster.
Post 786897 by mike 850 on 2015-09-26 11:55:48
Did a hot test today, results were Dry 105 105 120 115 105 Wet 140 140 155 145 135 So I can be pretty certain the rings need sorting, the more oil I put it the higher the compression went up, when sorting the cylinder head last year I spent a fair bit of time lapping the valves in so better start stripping the engine again
