Post 786981 by leet5r on 2015-09-27 21:22:30
evening fellas ,
got some new wheels for the cossie on Friday with a staggered offset
problem is the rear wheels stick out and catch the arch . so was thinking of getting them redrilled to 5x108 to fit the new t5
any one had this done ??
whats the pros and cons aswell
cheers
Post 786982 by AcidicDavey on 2015-09-27 21:32:41
Or just get some PCD adaptors made? Got to be easier?
Mind, 4x108 to 5x108 might be an issue.
Post 786983 by leet5r on 2015-09-27 21:49:22
no can do as then the offset would be way way out
Post 786984 by turbotony21 on 2015-09-27 21:58:34
personally wouldnt redrill wheels adaptors is only safe way but uve already said they will stick out to much just add on a set of bolt on arches and see wat they look like on
Post 786987 by leet5r on 2015-09-27 22:19:12
am not sticking arches on the cossie bud lol , could I machine the hub of the wheel and then use group A wheel nuts ??
Post 786991 by AcidicDavey on 2015-09-27 22:44:00
Probably best not to grind away material on the mounting face as you're likely to weaken the alloy.
Post 786995 by turbotony21 on 2015-09-27 23:02:32
ah for the cossie sorry thought u meant volvo yea da do that like still wouldnt redrill wheels m8
