Post 787170 by c70geoff on 2015-09-30 14:51:47
Just wondering if anyone has done an atf change on the box and if so how much atf you had to purchase to do said job as I'm finding it some what difficult to find the gearbox recommended amount and also its capacity
I'm sure there will be plenty in the torque converter but all I need is gearbox specifics please
Post 787172 by Soulboy on 2015-09-30 15:10:50
Hi,my mechanic friend did one on mine when I first bought it and used 12 litres by the time he'd finished flushing it,so it was red in colour instead of filthy black.
I've read some people using 15/16 litres, so I guess it's down to however dirty yours is.
Easy job though,drain the atf into a large measuring jug so you can replace the exact amount you remove,I did 4 litres each time(important to be spot on I was told),then using a length of half inch hose, you can refill through the dipstick tube(not how I was told but it worked a treat 15,000 miles ago),then finally the gearbox oil counter needs to be reset with Vida so the eml light doesn't appear prematurely.
Post 787175 by jamesy12345 on 2015-09-30 15:15:11
Says in here 3 litres for a fluid change, for P80 cars' 4-speed box
https://www.volvoclub.org.uk/tech/service/850/MaintenanceInfo.pdf (page 12)
But more will be used for flushing as above. I used Carlube ATF-U in my S70 T5
Post 787176 by abdul on 2015-09-30 15:30:27
Theres a good how too on youtube
Post 787180 by Kingsford G on 2015-09-30 15:43:55
It took 13L on my 4 speed box,all depends on how dirty it is.DX3 is suitable so not too expensive.
Post 787208 by Nealevo on 2015-09-30 19:54:23
Just over 12 litres from start to finish.
Post 789037 by c70geoff on 2015-10-21 18:13:27
8 litres from start to finish and running much better in gear
Stuff that came out was black and sludge like now it's a nice liquid smooth red
Yay and cheers guys
Post 789041 by M-R-P on 2015-10-21 18:32:11
This ginge or the turk mate?
Post 789042 by M-R-P on 2015-10-21 18:32:53
Oops.... Looks at heading... 70 series...
I'll get me coat.
