Hi everyone finally got here
Post 788928 by disco on 2015-10-19 23:31:45
Have been trying to get here for a while emails not my strong point on my forth and best volvo now. Have had it for about four years and it just keeps geting better rolling coal and sounds like nothing else dave DONT KNOW IF ANYONE HAS HAD THIS PROBLEM BUT IVE HAD IT A FEW TIMES NOW CAR STARTS IN THE MORNING EVERYTIME PERFECT DRIVES GREAT ,IF YOU SWITCH IT OFF FOR A COUPLE OF MINUITES IT WONT RESTART IT JUST CRANKS OVER AS IF IST OUT OF FUEL ..WAIT ABOUT TEN TWENTY MINS AND IT STARTS FINE IS IT AN IMOBILLISER FAULT OR DODGY FUEL FILTER HOPE SOMEONE CAN HELP THANKS PS WILL POST SOME PHOTOS ONCE IVE WORKED OUT HOW
Post 788931 by jamesy12345 on 2015-10-20 00:55:08
how do :welcome: hit the caps lock mate :) & let us know what is your car. We like photos Hot start problem? Do you know if the plugs are wet after cranking & no start? Could be coolant temperature sensor I mention that because there was a recent thread on a cold start problem (opposite to what you have) http://www.vpcuk.org/forums/showthread.php?60847-Can-anyone-in-North-East-help-me-diagnose-an-ETM-or-boost-leak&p=788462&highlight=#post788462 In your case if it is the coolant temp sensor, then you can try disconnecting the sensor's multiplug when warm & see if the car fires
Post 788932 by jamesy12345 on 2015-10-20 01:12:50
how do :welcome: hit the caps lock mate & let us know what is your car. We like photos Hot start problem? Do you know if the plugs are wet after cranking & no start? Could be coolant temperature sensor I mention that because there was a recent thread on a cold start problem (opposite to what you have) http://www.vpcuk.org/forums/showthre...ht=#post788462
Post 788933 by jamesy12345 on 2015-10-20 01:14:14
Post 788938 by cherrywaves on 2015-10-20 07:23:03
"Hello, good evening & welcome" !!!! Pictures,pictures...pictures!!!! (Mine are to follow later - honest!!) If you've got an 850/P1 V70 like i have, my thoughts were "Battery, Immobiliser, dizzy, leads, plugs, engine management etc" as a last resort i'd suggest pulling the fuel pump and giving it a digital test with a volt meter or an analogue test with a hammer - its what diagnosed my "cranks but wont fire issue".
Post 788943 by Santa on 2015-10-20 08:36:46
Post 789002 by disco on 2015-10-20 22:08:16
Sorry about that dam keyboard mines a 1997 2.5 tdi se and have never seen another one the same colour cheers
