Post 789821 by Rhys on 2015-11-01 19:08:56
I'm after some tyres for my T5, and am wondering what size I can use (apart from the obvious normal size). Wondering if I can get away with 55's or would they rub? Also would 195 be ok? Just wondering as I'm after a winter set and checking out fleabay etc for a part worn set as I'm a tight northerner. Obviously, I would have to make sure the load rating is high enough..
Any thoughts?
Can't remember the name of the alloys off hand (later version of Columbas which came out on the V70)
Post 789830 by kmb on 2015-11-01 19:45:03
Try this site, very helpful: http://www.willtheyfit.com/
Post 789833 by stribo on 2015-11-01 20:21:33
You could fit 195/55/16s, but they're a bit skinny IMO.
Post 789850 by Rhys on 2015-11-01 21:37:53
[QUOTE=stribo;789833]You could fit 195/55/16s, but they're a bit skinny IMO.[/QUOTE]
Thought so, the 205 55 16 would rub on the arches IIRC? Skinny tyres are better for snow though, we're supposed to have the mother of all winters coming up lol (better get my shorts and sunglasses out..)
Post 790123 by RichT4 on 2015-11-05 21:41:37
Just to give my 2p's worth, i'm currently running on 225/55/R17's, so if mine don't rub, i'm sure yours won't :) Just get the bump stops changed.
Post 790127 by Rhys on 2015-11-05 22:41:35
[QUOTE=RichT4;790123]Just to give my 2p's worth, i'm currently running on 225/55/R17's, so if mine don't rub, i'm sure yours won't :) Just get the bump stops changed.[/QUOTE]
It already has the turning circle of a barge lol (compared to our lass's Honda Jazz anyway..)
Post 790131 by Yosser on 2015-11-06 02:00:29
I ran that very car on 205/55/16 winter tyres on steel wheels.
They did rub on full lock but it wasn't a big deal.
The car performed very very well in the severe winter we had a few years back.
I still have the wheels & tyres here......
Post 790135 by Rhys on 2015-11-06 06:58:35
[QUOTE=Yosser;790131]I ran that very car on 205/55/16 winter tyres on steel wheels.
I still have the wheels & tyres here......[/QUOTE]
Thats what I needed to know, thanks.
Post 790211 by disco on 2015-11-07 13:24:51
hi there dont know if this helps with the winter idea but ive got 225 45 16 toyos on mine and no probs havent tried in the snow yet but great in the wet os we dont get a lot of the white stuff in sunny plymouth Dave
Post 790230 by kmb on 2015-11-07 16:38:21
[QUOTE=disco;790211]hi there dont know if this helps with the winter idea but ive got 225 45 16 toyos on mine and no probs havent tried in the snow yet but great in the wet os we dont get a lot of the white stuff in sunny plymouth Dave[/QUOTE]
I was wondering about whether this combination worked OK and improved grip:
Here's the comparison 205 50 16 versus 225 45 16
Diameter: 611.4mm 608.9mm
Circumference: 1920.8mm 1912.9mm
Speedo error: 0% 0.41%
Reading at 30mph: 30mph 30.12mph
Reading at 60mph: 60mph 60.25mph
Ride height gain: 0mm -1.25mm
Arch gap loss: 0mm -1.25mm
Good to know they don't rub - Although I was wondering if 225 was too wide for the standard 6.5" T5 wheels?
Post 794440 by Foeux on 2016-01-05 11:01:49
I run 205/55/16.
They rub a tiny amount on full lock but nothing loathsome.
Interestingly they are ususally cheaper than 205/50/16 as the 55 profile si what all new polos, ibizas, fabias etc run as standard.
