Post 789863 by Tee5alive on 2015-11-02 09:46:26
put over 3000 miles on the car since the rebuild (new turbo, alternator etc) and initially this problem was small. But gradually this is getting more pronounced. Even trying TOP GRADE 'super' petrol its happening.
Under hard acceleration the car boosts hard then backs off, then boost/back off etc ??? I have replaced the ETM body and this was initially suspect to no avail. It is getting VERY pronounced and boost is kicking in with a vengeance at times almost putting me through the drivers seat, wheels spinning etc (even at motorway speeds) - THEN drops to nothing?
I am getting an intermittent ENGINE SYSTEM SERVICE due and now and then BRAKE ASSIST SYSTEM SERVICE. Which knocks out CRUISE control.
Is this possibly simply an air leak somewhere as now and then the turbo sounds a little LOUD in the car. The car otherwise is fine, just a bit embarrassing when peak acceleration is called for!
ideas please??
Post 789869 by Soulboy on 2015-11-02 11:12:32
I had this same problem and only got to the bottom of it last week, turned out to be the map sensor
With that replaced it boosts the same all the time, everytime
However, if you wanna try the tcv first, I have a spare here that I bought while chasing the fault that you are welcome to try (-:
Post 789877 by Tee5alive on 2015-11-02 14:13:38
[QUOTE=Soulboy;789869]I had this same problem and only got to the bottom of it last week, turned out to be the map sensor
However, if you wanna try the tcv first, I have a spare here that I bought while chasing the fault that you are welcome to try (-:[/QUOTE]
thanks Soulboy, on my next pitstop when I can do some work on her I'll give that a try - ill be in touch!
Post 789881 by Soulboy on 2015-11-02 14:37:27
No worries mate,pm me your address and I'll send it to you!
Post 789892 by Shinsplintz 101 on 2015-11-02 17:49:24
I don't want to muddy the water..... BUT... my old mans old late P1 T5 had a similar problem & it was the ABS module. Threw up weird engine warning lights, codes & intermittent boosting issues [probably due to the ECU ££££ting itself with the codes]. Don't know if the P2's suffer with the same dodgy ABS modules, but thought I'd throw it out there...good luck :)
Post 789903 by expolicev70t5 on 2015-11-02 20:17:27
Got same issue on mine, then I get an over boost code and boost cut. I've got it down to be TCV that's faulty.
Post 789943 by Tee5alive on 2015-11-03 15:35:31
[QUOTE=Shinsplintz 101;789892]I don't want to muddy the water..... BUT... my old mans old late P1 T5 had a similar problem & it was the ABS module. Threw up weird engine warning lights, codes & intermittent boosting issues [probably due to the ECU ££££ting itself with the codes]. Don't know if the P2's suffer with the same dodgy ABS modules, but thought I'd throw it out there...good luck :)[/QUOTE]
INTERESTING as I start off with no codes then an ENGINE SERVICE on the DIM and then BRAKE ASSIST advisory - hmmmm thats interesting. Thank you all
Post 789945 by Orca2 on 2015-11-03 18:06:31
Could be cracked abs rings, they open up when you boot it , the abs sensors then see the crack and cut your power cos they assume you are skidding, mine used to do it on roundabouts new rings cured it. The abs fault was dumping all the boost .
Post 789974 by Mart5in on 2015-11-03 23:16:15
[QUOTE=Tee5alive;789943]INTERESTING as I start off with no codes then an ENGINE SERVICE on the DIM and then BRAKE ASSIST advisory - hmmmm thats interesting. Thank you all[/QUOTE]
The brakes don't feel heavy at any point do they? Might be worth checking the pipe that goes from the manifold to the brake servo. It's got a little one-way valve on it.
As far as I know (what my local Volvo dealer told me) the P2 don't suffer from the same ABS module faults as the P1 did. all the P2's normally fail on the front sensors and rings. Rarely the rear sensors.
When you changed the ETM, did you fit one from another Volvo and have it coded? Or did you have it repaired with the contactless tps?
Post 790355 by Tee5alive on 2015-11-08 20:02:56
[QUOTE=Mart5in;789974]The brakes don't feel heavy at any point do they? Might be worth checking the pipe that goes from the manifold to the brake servo. It's got a little one-way valve on it.
When you changed the ETM, did you fit one from another Volvo and have it coded? Or did you have it repaired with the contactless tps?[/QUOTE]
NO Martin just bought a used ETM fitted it , disconnected battery to reset and that was it, BUT still hunting a little on idle
ORCA - THAT is interesting about the rings will check it thanks all
Post 790424 by Harvey on 2015-11-09 19:55:32
[QUOTE=Tee5alive;790355]NO Martin just bought a used ETM fitted it , disconnected battery to reset and that was it, BUT still hunting a little on idle
ORCA - THAT is interesting about the rings will check it thanks all[/QUOTE]
Next time you're down south give me a shout & I can stick my code reader on it .
Post 791874 by LeeT5 on 2015-11-23 22:17:46
Another dead thread with no result and no response.
Post 791880 by Mart5in on 2015-11-23 22:40:36
Well, I know I'm not op but my situation was VERY similar and a new MAF combined with the ETM repair fixed it :)
all I've got left is a misfire from cold under load. can't set off without letting the engine run for a few mins.
Post 791895 by LeeT5 on 2015-11-24 08:15:55
[QUOTE=Mart5in;791880]Well, I know I'm not op but my situation was VERY similar and a new MAF combined with the ETM repair fixed it :)
all I've got left is a misfire from cold under load. can't set off without letting the engine run for a few mins.[/QUOTE]
Have you changed your plugs? Fit Genuine.
Post 791919 by Mart5in on 2015-11-24 10:51:29
Yeah, I did change the plugs. Not Volvo, I used ngk but theyre the same heat rating if I remember correctly. I can't remember if the problem was there before I changed the plugs. I'll try the old genuine plugs back in sometime this week.
