Replacement stereo?
Post 790598 by petrolh34d on 2015-11-11 16:50:30
Hi guys I'm looking to replace the head unit on my 1997 V70. I want to keep it looking as tidy as possible, but can't seem to find a stereo that has a face plate that will cover up the old one. What should I be looking for here, or how is this achieved?
Post 790599 by p fandango on 2015-11-11 17:41:50
Any double din unit should fit, on 850's there was a central runner that had to be cut once the factory radios removed & think it'll be the same on that
Post 790601 by 500tie on 2015-11-11 18:59:49
The guide runner is indeed still on the V70's you can just file this down if you want to fit a double din unit. Or you can fit a single din unit and a plastic shelf type thing which is the perfect size for a phone etc. This is an old photo now but you get the idea Image
Post 790699 by petrolh34d on 2015-11-13 13:33:45
Ah, so that's what double DIN means! Thanks guys
Post 799702 by petrolh34d on 2016-04-17 15:43:07
Sorry if these questions are stupid, but I have 0 knowledge of ICE and associated terminologies. I bought a Double DIN Pioneer SPH-DA100, but it doesn't fit properly into my dashboard. It didn't come with any fixtures. What do I need to get to make it fit properly? [ATTACH=CONFIG]30565[/ATTACH]
Post 799703 by jamesy12345 on 2016-04-17 16:34:53
See this thread below fella http://volvospeed.com/vs_forum/topic/150250-easy-double-din-install-volvo-850x70/ You need an installation kit with a cage & fascia panel, maybe the one below but I'm not 100% (trim surround might not match for example) http://www.ebay.co.uk/itm/PIONEER-SPH-DA120-100MM-Replacement-Double-Din-Car-Stereo-Radio-Headunit-Cage/351346290225?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D35391%26meid%3Dd97c78d97ce4478a9d9f30f483bec92f%26pid%3D100005%26rk%3D1%26rkt%3D2%26sd%3D251676479504 Do the mult-plugs & aerial connect OK? If not you can get adaptor looms
Post 799706 by petrolh34d on 2016-04-17 17:33:04
Got the adaptor loom the other day, and have the stereo plugged in and working. Just bought that installation cage of eBay, so will have the stereo properly installed during the week. I see that it was supposed to come with a microphone for use with Bluetooth phone calls as well. Mine didn't come with a mic, but I see that the OEM mic has a standard issue 3.5mm headphone jack on it. [ATTACH=CONFIG]30566[/ATTACH] I'll buy one eventually, but I've got an old PC mic lying around somewhere that I'm pretty confident I can bodge in the mean time. (As much out of curiosity as out of being tight)
Post 799707 by jamesy12345 on 2016-04-17 17:56:44
I was just doing the same thing on another car, with a single DIN Nakamichi CD-400 [ATTACH=CONFIG]30567[/ATTACH] Ebay contains all the things we could ever (& never) want http://www.ebay.co.uk/itm/PIONEER-SPH-DA100-BLUETOOTH-MICROPHONE-MIC-SPH-DA100-NEW-C2-/172106589087?hash=item28125a239f:g:jwgAAOSwQJhUepKs
Post 799713 by MoleT-5R on 2016-04-18 09:02:26
[QUOTE=jamesy12345;799707]I was just doing the same thing on another car, with a single DIN Nakamichi CD-400 [ATTACH=CONFIG]30567[/ATTACH] Ebay contains all the things we could ever (& never) want http://www.ebay.co.uk/itm/PIONEER-SPH-DA100-BLUETOOTH-MICROPHONE-MIC-SPH-DA100-NEW-C2-/172106589087?hash=item28125a239f:g:jwgAAOSwQJhUepKs[/QUOTE] For the single din set-up there is a neat six drawer cd storage tray that can be fitted to fill the gap, which I have in my olive look like it has always been there as it is a volvo part, which I ordered through the local stealer and the matching mounting trim for it, where still available for p1 v70's a few years back, so may still be if you fancy one for yours....:)
Post 799715 by jamesy12345 on 2016-04-18 10:27:36
[QUOTE=MoleT-5R;799713]For the single din set-up there is a neat six drawer cd storage tray that can be fitted to fill the gap, which I have in my olive look like it has always been there as it is a volvo part, which I ordered through the local stealer and the matching mounting trim for it, where still available for p1 v70's a few years back, so may still be if you fancy one for yours....:)[/QUOTE] thanks Adrian I'll check it out, didn't know about it until your post. Found it on page 69 on the brochure below: http://accessories.volvocars.com/LegacyCatalog/Pdf/X70_audio_FR_GB_NL_DE.pdf CD-compartment Grey 9192 749-1 Black 9192 748-3 + ISO Bracket Grey 9192 751-7 Black 9192 750-9
Post 799718 by MoleT-5R on 2016-04-18 12:14:04
[QUOTE=jamesy12345;799715]thanks Adrian I'll check it out, didn't know about it until your post. Found it on page 69 on the brochure below: http://accessories.volvocars.com/LegacyCatalog/Pdf/X70_audio_FR_GB_NL_DE.pdf CD-compartment Grey 9192 749-1 Black 9192 748-3 + ISO Bracket Grey 9192 751-7 Black 9192 750-9[/QUOTE] oh forgot it takes 8 but that's the one, really useful and looks good fitted, handy brochure that and lots of useful info in there thanks
