Post 790812 by Uzulins on 2015-11-14 21:44:38
Now have problem with engine, head gasket gone, but so thiny leak that even cant notice, only on full boost Temp guage jumps up.
Car is daily so cant live without her.
Iwe got other engine, and today removed Valve cover, and oil sump, checked all liners looks very solid, engine turns very easy, but it got 200 000 or somthing near that, just woundering, should i change piston rings, and clean valve seats, or i can just swap engine? And how its easier remove engine from car with gearbox or without gearbox?
Cheers.
Here is some pics.
And does somebody know why head and valve cover has different numbers? It should be like that? Cheers.
Post 790813 by Uzulins on 2015-11-14 21:45:13
[QUOTE=Biff;790811]Nice to see an 854 t5r![/QUOTE]
Thanks Biff
Post 790816 by Uzulins on 2015-11-14 21:56:12
My liners looks like this
Got loads of horizontal little scratches and non vertical. Is it good?
(in pic is not volvo engine, just for example)
Post 790817 by Ettienne on 2015-11-14 21:59:47
Is that not the original cross hatching finish from honing, measure the ring gap to check for wear.
Post 790818 by Uzulins on 2015-11-14 22:02:49
[QUOTE=Ettienne;790817]Is that not the original cross hatching finish from honing, measure the ring gap to check for wear.[/QUOTE]
Then i should remove head. There is mno way to check that without removing head? Cheers, this engine is with good headgasket.
Post 790819 by Ettienne on 2015-11-14 22:05:25
Put a ring down the cylinder, square it off with pushing a piston behind it, the take a feeler gauge to the ring gap and measure it.
Post 790821 by claymore on 2015-11-14 22:40:21
Engine was just over 100k miles when Dan had it off me, so nowhere near 200k ;)
Post 790826 by Uzulins on 2015-11-15 00:03:45
[QUOTE=claymore;790821]Engine was just over 100k miles when Dan had it off me, so nowhere near 200k ;)[/QUOTE]
I bought spare engine, just chacked bearings they look like new.
I will rebuild ''old'' one after when i finish this one.
Colin, this wich is in my 850 has 100k spare one has 200k
You can see engine which is 200k is with torque converter.
Post 790832 by Uzulins on 2015-11-15 01:11:11
After torque converter removal from flywheel i need balance it?
Cheers
Ed
