Nebula's on s40
Post 790863 by GazzR on 2015-11-15 13:13:16
Hi im looking at buying some 18" nebula's to put on my 2009 s40 r design and would like to know do they come in different offsets. If so which ones will fit my car, any help would be great. Thanks
Post 790864 by stephenevans99 on 2015-11-15 13:18:23
They'll fit straight on, although you may want to fit spiggot rings to centre them correctly when fitting - Nebs are 65.1mm centre bore as opposed to 63.4mm on the S40. Offset is 49mm.
Post 790865 by stephenevans99 on 2015-11-15 13:22:28
The only other thing to consider would be the tyre size and rubbing issues.....Nebs were supplied with 235/40R18s which even rubbed on the P2s, I reckon for the S40 you should be looking at 225/45R18s
Post 790872 by GazzR on 2015-11-15 14:34:11
Thanks bud, i currently have medusa's on with 225/40/18 tyres on so i was planning to use this size tyres anyhow. Any idea where i would get the spigot rings i would need?
Post 790876 by stribo on 2015-11-15 14:55:24
http://www.ebay.co.uk/itm/SPIGOT-RINGS-63-4-65-1-FORD-VAN-CABRIOLET-RS-ST-MONDEO-XR2i-BBS-RH-CH-WELLER-/140726147603?hash=item20c3ee9a13:g:fU8AAMXQhpdRr9eU
Post 790878 by GazzR on 2015-11-15 15:21:20
Thanks for your help lads.
