Post 791775 by richcoad89 on 2015-11-23 11:09:27
Hello,
I have a whoteblock with a KLRacing adaptor with a Getrag 265/5 GB from the 535i, a more and more common combo being seen these days. I've had it working, but my problem is when the engine is running its tricky to get it into gear.
I'm happy it's not a clutch issue, and my first thoughts are related to the input shaft to crank bearing adaptor the previous owner of the engine and gearbox had made.See pic for info.
It doesn't seem well made and isnt strait or true so I've ground it off and will get a new piece machined so it fits proper and is true.
Has anyone who has done this conversion/adaption know of a similar issue or work around?
Thanks in advance.
Rich.
*pic to follow
Post 791780 by jamesy12345 on 2015-11-23 12:19:33
This was going in the RX7 in your avatar wasn't it....does that mean it is up & running..?
http://www.vpcuk.org/forums/showthread.php?54763-Mazda-RX7-with-B5234FT-T3-build-thread-link&p=691215&highlight=#post691215
Project thread needs an update though if you are driving it around :) many many more pictures please!!
Post 791796 by richcoad89 on 2015-11-23 14:40:08
That's the one!! Il direct you to my build thread
I put it on the norortors website as was a little more specific.
http://www.norotors.com/index.php?topic=18908.0
Lots of pics here, and yes was driving, but I've since stripped it back for a full respray, now it's going back together again!! Exciting times.
Post 791798 by jamesy12345 on 2015-11-23 15:18:21
[QUOTE=richcoad89;791796]That's the one!! Il direct you to my build thread
Lots of pics here, and yes was driving, but I've since stripped it back for a full respray, now it's going back together again!! Exciting times.[/QUOTE]
Nice job...I see what you mean about the distributor clearance! Selling the parts you have stripped off the car also might help to recover some of the cost of the project? 13B engine & box, APEXI ECU & controller would sell - I'm on the FDUK forum
Sorry for thread hijack & lack of useful information :redface:
Post 791861 by richcoad89 on 2015-11-23 20:58:02
Already have sold everything I don't need! I don't have the space either!
The project has paid for itself so far just from selling unneeded parts :-)
Post 792485 by oblark on 2015-12-03 19:14:44
Are you using a spigot bearing in the end of the crank ?
Post 792920 by richcoad89 on 2015-12-10 10:44:14
Hi Oblark
Yes that was the plan, the gearbox shaft doesn't reach the bearing though and theyre different diameters also
Post 794265 by richcoad89 on 2016-01-02 15:23:27
Il let you know if it worked in a few weeks!
Post 794329 by oblark on 2016-01-03 19:33:51
Thats what I thought was the problem was, thats why I asked about the spigot brg.
My redblock M90 imput shaft is long enough to reach the spigot brg with the 10mm thick adaptor plate.
Post 794449 by richcoad89 on 2016-01-05 13:39:47
Ideal, have you encountered any problems? I'm hoping this cures my "not going into gear when engine running" issue. Only time will tell!
