V70r aka Darth Vadar
Post 800326 by Doingitsideways on 2016-04-29 23:19:04
Love the Lego battery cover :)
Post 800329 by Ettienne on 2016-04-30 10:32:01
[QUOTE=Doingitsideways;800326]Love the Lego battery cover :)[/QUOTE]
They look good, I saw a few at incarnation, best thing they come in lots of colours
Post 800872 by jamin on 2016-05-12 21:32:14
It looks well made, how easy was it to fit and how does it sound?
Post 800878 by Robbin Houses on 2016-05-13 07:37:08
I had the original system on so needed to cut it off, or you would have to swing the rear axle down. But pretty standard exhaust swap!! Bit louder then the standard exhaust at idle, but when you give it some beans it roars!!
Post 800880 by Biff on 2016-05-13 09:05:05
Looks cracking. You want to speak to Don about an mte map once you get a 3" dp.
Totally transforms the car.
I want another R badly. :(
Post 800883 by Robbin Houses on 2016-05-13 10:10:52
Wheres the best place to get 3" down pipe? Im impressed at how much response ive got from putting the new catback on...saying that the old one was blowing like hell!!
Post 800889 by Biff on 2016-05-13 11:14:26
[QUOTE=Robbin Houses;800883]Wheres the best place to get 3" down pipe? Im impressed at how much response ive got from putting the new catback on...saying that the old one was blowing like hell!![/QUOTE]
Ferritta do one which is a lovely bit of kit as you will of seen with your cat back.
a Guy called Graeme Welch used to make them on here (you might see a gwe dp advertised from time to time) but I've heard conflicting reviews on the fit of the dp.
Don might be worth speaking to but I'm sure they were £600 last time I checked.
I had exactly the same on my V70r, the exhaust was awful so I changed it for a Jetex Duplex which highlighted how rotten my original was, within weeks it blew my cat & dp to bits. Absolute nightmare job on an awd. Never again!
Mine had 3" dp, sports cat 200 cel & the 2.5" system & with the map I managed 272bhp on white injectors which yours will already have. You don't say if its a manual or auto, if its man then you have an 18t turbo & should get a fair bit more power with a stage 2 map. Mine was a 16t which the t5's are fitted as standard (so are the auto R's).
hope this helps.
Post 800893 by Robbin Houses on 2016-05-13 14:03:45
Yeah mines an auto, Don did say the DPs are £600 but was wondering if theres any other types available, do you know if theres a decat pipe available? Was thinking intercooler next but now might be swaying towards the DP. Also is there much benefit to get a dump valve instead of the standard recirc valve
Post 800894 by Biff on 2016-05-13 14:19:29
[QUOTE=Robbin Houses;800893]Yeah mines an auto, Don did say the DPs are £600 but was wondering if theres any other types available, do you know if theres a decat pipe available? Was thinking intercooler next but now might be swaying towards the DP. Also is there much benefit to get a dump valve instead of the standard recirc valve[/QUOTE]
No mate you want to avoid dump valves, get yourself a re-circ blanking plate & a 10mm ratchet spanner with a pivoting head to fit the bugger. Its a bit awkward to get to but you will have glorious wastegate chatter. If you do want a dump valve for the pitissssh then you need a forge twin piston but I'd do the plate first & see what you think. They are about £15 off fleabay.
You will need to go custom on the de-cat, I don't know of any off the shelf but again that should be cheap ( I've paid £60 for previous cars). Someone may correct me on that.
The intercooler will be fine (if its not split) for up to 300bhp but you will probably need a manual conversion before then as the auto boxes aren't a fan of serious horses.
Post 800896 by Robbin Houses on 2016-05-13 15:39:59
Id like to hit the 300bhp mark so what would you suggest is the next bits to go for? DP and cat? Im abit of a newbie to volvos and this is my first turbo'd car
Post 800984 by Biff on 2016-05-16 12:24:02
[QUOTE=Robbin Houses;800896]Id like to hit the 300bhp mark so what would you suggest is the next bits to go for? DP and cat? Im abit of a newbie to volvos and this is my first turbo'd car[/QUOTE]
Yes dp, decat & a map should get you nearer but for 300 you'll need a bigger turbo, injectors & the jedi force.
Post 801271 by Robbin Houses on 2016-05-23 22:16:51
This weeks purchases have arrived...going to try and fit them next week....
Post 801293 by Biff on 2016-05-24 10:12:53
[QUOTE=Robbin Houses;801271]This weeks purchases have arrived...going to try and fit them next week....
[/QUOTE]
Use Volvo bump stops & strut tops & they will be fine. :)
Post 801426 by Robbin Houses on 2016-05-26 21:54:41
I read some where about leaving the rear spring adjuster out so you can get the back end lower? Trying to organise a day i can get it in at work to put them on!!
Post 801431 by Biff on 2016-05-27 09:00:37
Yeah mine had the adjuster left out.
It wouldn't go much lower than this...
Post 801475 by Tomcat on 2016-05-28 17:08:23
Nice to see another V70 build thread.
Post 802240 by Robbin Houses on 2016-06-19 21:02:45
After alot of shouting, swearing, throwing things the v70 is now finally lower!! No knocks or bangs and im fairly happy!! I wouldnt recommend pro sport coilovers to anyone and as soon as i can i will be buying something to replace them!!! Thanks to everyone who replied to the PMs just wish i had saved some more $$$$$ instead!!
Here it is
Post 802241 by foammanmark on 2016-06-19 21:18:40
Looking good, and the front looks lower than mine but the rear looks standard,
Post 802242 by Robbin Houses on 2016-06-19 21:41:09
Yeah its not the best pic, but its deffo lower then standard!! Ill try get another depending on light!
Post 802243 by Robbin Houses on 2016-06-19 21:47:14
Here you go
Post 802244 by foammanmark on 2016-06-19 22:05:59
Looks about the same as mine which isn't lowered as far as I know.
Post 802245 by Robbin Houses on 2016-06-19 22:21:10
No yours must be mate, if you look at some of the pics earlier on you will see the back of mine was like a monster truck!
Post 802472 by Robbin Houses on 2016-06-25 14:01:16
So was on my way to Goodwood yesterday when i heard a hissing noise from under the bonnet...had a look and its just a loose jubilee clip, go to tighten it up and the hole top hose comes off in my hand!! The top hose inlet/outlet has come away from the rad!!!
Any one know where i can get the oil pipe clips from? Mine are looking a bit worse for wear!!!
Post 802477 by Biff on 2016-06-25 17:40:19
[QUOTE=Robbin Houses;802472]So was on my way to Goodwood yesterday when i heard a hissing noise from under the bonnet...had a look and its just a loose jubilee clip, go to tighten it up and the hole top hose comes off in my hand!! The top hose inlet/outlet has come away from the rad!!!
Any one know where i can get the oil pipe clips from? Mine are looking a bit worse for wear!!![/QUOTE]
Volvo mate. Were about £33 when I got them.
Cars looking well, I'd go for koni yellows & eibach pro on my next one.
Great combo.
Post 802499 by foammanmark on 2016-06-26 15:37:37
[QUOTE=Robbin Houses;802245]No yours must be mate, if you look at some of the pics earlier on you will see the back of mine was like a monster truck![/QUOTE]
Mine is sat so that the very top of the tyres aren't visible but I have no reason to think that she has been lowered than standard tbh.
Post 802936 by Robbin Houses on 2016-07-09 14:53:01
Got back from spain and thought better get round to changing the rad, fitted fine and running it up as we speak so thought while im waiting id fit my new horns... Twin Hella panthers..
