Dropped piston sleeve xc70
Post 792683 by telboy on 2015-12-06 15:58:53
Any ideas appreciated, I have been getting low coolant message a lot and filling up, had it in garage for a new head gasket and told one of the piston sleeves had dropped 4 thousandths of a mill so pressurising the coolant system. head was put back and torqued down a bit more to try and compensate which worked for a while, however problem now back. I have tried steel seal as its supposed to cure this but to no avail, anybody got any thoughts. want to keep it going for about another year, xc70 2002 with only 218k on the clock, not even run in yet.
Post 792684 by claymore on 2015-12-06 16:07:53
I'm not sure it's possible for a liner to drop on these engines, how often are you having to top up the coolant?
Post 792686 by Yosser on 2015-12-06 16:15:31
Is it a petrol or diesel? The usual suspect is cracked liner if it's a petrol.
Post 792687 by jamesy12345 on 2015-12-06 16:15:56
Eh I thought the sleeves were cast into the block Is it possible that one of the liners has cracked? //edit to slow as usual :)
Post 792715 by Harvey on 2015-12-06 19:13:42
Worth a phone call to Mr Williams ?
Post 792716 by Harvey on 2015-12-06 19:28:02
But a 2002 car would be a 2.4 engine .
