Post 793678 by 500tie on 2015-12-23 21:20:47
Hi all,
I'm about to put a set of subwoofers in the boot of my V70 and I'm wondering if anybody knows a good route for the power lead through the bulk head? I've looked from the engine side but can't see any existing bungs or wiring looms to follow.
Can anyone shed any light if there is a good route that's already in place?
Post 793679 by p fandango on 2015-12-23 21:56:25
it'll be the same as an 850, the best one i found was under the brake servo. Leads to under the glovebox
Post 793681 by 500tie on 2015-12-23 22:22:23
My brake servo is on the drivers side of the car though, I may have to have a look around under the glove box though thanks for that
Post 793683 by martin_r_smith on 2015-12-23 23:09:35
What subs did you go for in the end?
Post 793685 by p fandango on 2015-12-24 01:27:44
[QUOTE=500tie;793681]My brake servo is on the drivers side of the car though, I may have to have a look around under the glove box though thanks for that[/QUOTE]
sorry, i meant the under the ABS pump/valve on the passenger side of the car
Post 793689 by 500tie on 2015-12-24 08:08:28
Ah got ya thanks mate, Martin I'm going for the twin pre amped 12" Fli subs. They're the best fit and colour matches my boot carpet a little better than the black vibe ones. Have you had any thoughts on what you're going to do mate?
Post 793690 by p fandango on 2015-12-24 08:50:41
my interior's stripped, but you can get a bit of a judgement where it is from this pic
Post 793704 by 500tie on 2015-12-24 14:15:29
Nice one thanks for that mate, I wonder if I can access that bung by just removing the glovebox?
Post 793712 by Dangerous Dave on 2015-12-24 16:19:55
There should be some spare conduits that go through the bulkhead. They have rubber caps on the end with multiple cable glands. There should be spare ones both sides of the car. They then drop down into the depths of the footwell.
I used one of these on the near side to route my amp power cable then down the side of the footwell into some trunking which runs cables to the back of the car along the door sills (under the plastic strips by the carpet)
Hope this helps
Post 793716 by 500tie on 2015-12-24 17:45:02
Thanks Dave I'll have a look for them
Post 793720 by p fandango on 2015-12-24 18:11:24
[QUOTE=500tie;793704]Nice one thanks for that mate, I wonder if I can access that bung by just removing the glovebox?[/QUOTE]
you should be able to, my wire was originally put in when i had the interior in
