S60R Steering solenoid
Post 794658 by Markyb on 2016-01-09 11:04:22
Mines on its way out, does anyone know what part number/ name i am looking for? Or a link to where i can buy one from in the uk? Internet search shows plenty of people talking about them but nothing concrete as to where and what to buy
Post 798633 by Harvey on 2016-03-26 10:16:27
You could just go to Volvo for it No 30741754 this is the repair kit .it's around £55 for the kit.
Post 799496 by LeeT5 on 2016-04-13 08:08:13
[QUOTE=Harvey;798633]You could just go to Volvo for it No 30741754 this is the repair kit .it's around £55 for the kit.[/QUOTE] I don't think he means THAT solenoid Harvey....that's on the rack. If your symptoms are intermittent HARD steering, then you need to replace the servotronic relay and it lives under the drivers side footwell above the brake pedal. Fairly easy to replace but you need to be a contortionist. I replaced mine a few years ago.....difference was incredible and instant! Symptoms described here...http://forums.t5d5.org/topic/15003-s60r-v70r-heavy-steering/
Post 799758 by Harvey on 2016-04-19 07:43:58
This is the relay - Amp I think the part number has been changed now. It's not as cheap as you think it will be :( Image Also this is the valve .on the rack which the relay - Amp controls . Image
