bleeding brakes
Post 794975 by MIXA on 2016-01-12 21:47:34
I plan on changing the flexy pipes to goodridge and any metal that need it to copper fitting repair kits to all calipers including pistons draining all old fluid , i have all the bits i will need and a Gunson easybleed kit what i was wondering is will i have to bleed it in any special way with it having ABS ,or is it just longest run first down to shortest , do i need to have the motor running to activate the abs ? thanks in advance
Post 795006 by M-R-P on 2016-01-13 14:36:15
Rear left, rear right, front left front right. I prefer to gravity-bleed but it takes ages. No need to run the car.
