That time again...
Post 794993 by M-R-P on 2016-01-13 11:25:25
The sweed is sitting in the carpark at my trusted local MOT place, awaiting this year's failures...
Tyres?
Track rods?
Emissions?
Lights?
Probably all of the above to be honest, I've not had much time to work on her the last few months - I've still not got round to fitting the 19t!
If she doesn't fail too badly today, I'll have her off the road for a while and pamper her a bit :) (that's if the MOT repairs don't financially cripple me lol)
Post 794994 by p fandango on 2016-01-13 11:34:45
please don't tell me you've not even bothered to check all the lights work
hope it passes tho
Post 794995 by M-R-P on 2016-01-13 11:43:40
I checked / changed the lights last night but since fitting the led headlights, there might be an issue there.
Post 794996 by yorkshire R on 2016-01-13 11:48:39
mine is due in a few weeks,i'm sure i wont be as jammy as last year as there was no advisory's or any sign of any! i have only done about 2000 miles.living in the country with really poor roads i'm guessing there will be something suspention wise!
Post 794998 by p fandango on 2016-01-13 12:25:50
[QUOTE=M-R-P;794995]I checked / changed the lights last night but since fitting the led headlights, there might be an issue there.[/QUOTE]
i used to get advisory for having white LED's in the sidelight (wrong colour) so you may get the same for that
Post 795001 by M-R-P on 2016-01-13 13:33:35
Failed.
Headlights and knackered windscreen wiper.
A few advisories but I've not seen the paperwork yet, I'll report back on that later.
Post 795003 by jamesy12345 on 2016-01-13 13:47:10
Surprised at that, you're not giving me much hope of getting this Renault through an MOT...the Sweed looked in good nick last time I saw it
Post 795004 by M-R-P on 2016-01-13 13:49:58
It's in great nick for 220k, the advisories are probably handbrake and track rods.
I knew the wiper was shot but didn't have time to buy one.
Mechanically, she's sweet as.
Post 795005 by M-R-P on 2016-01-13 13:50:44
Frankly, I'm surprised it passed the emissions test, what with the sports cat and greens :)
Post 795007 by Ettienne on 2016-01-13 15:07:12
Easy stuff at least you'll be able to make Dyno and ace cafe
Post 795008 by M-R-P on 2016-01-13 15:11:17
Yep.
Gonna get the ticket sorted for another year and start fiddling with it again. Rear brakes will be on the list as well as finally getting that 19t on.
Tranny flush and service will be first on the list tho.
Post 795009 by p fandango on 2016-01-13 15:22:06
what turbo's on it now?
Post 795013 by M-R-P on 2016-01-13 16:05:39
[QUOTE=p fandango;795009]what turbo's on it now?[/QUOTE]
16t
Post 795723 by M-R-P on 2016-01-28 10:17:06
So, the advisories were front tyres worn close to legal limit, o/s track rod worn, rear droplinks.
I'll get those sorted shortly along with...
Transmission flush.
Handbrake overhaul.
Steering flush.
Brake/clutch flush.
Service.
Bloody good clean inside and out.
Post 795724 by kmb on 2016-01-28 10:30:41
I was thinking of getting a PAS fluid flush on my car, is it fairly easy and cheap (if not doing it myself)?
Post 795725 by M-R-P on 2016-01-28 10:32:55
2 bottles of Volvo steering fluid and a big syringe.
Empty reservoir, fill with clean, steer lock to lock a few times and repeat until fluid looks clean. Usually takes about 1.5 bottles.
Post 795790 by kmb on 2016-01-29 12:28:24
[QUOTE=M-R-P;795725]2 bottles of Volvo steering fluid and a big syringe.
Empty reservoir, fill with clean, steer lock to lock a few times and repeat until fluid looks clean. Usually takes about 1.5 bottles.[/QUOTE]
Think I can manage that, will check on Amazon for the correct PAS fluid and maybe do next week when UK side :)
Post 795791 by M-R-P on 2016-01-29 12:36:29
Use genuine Volvo stuff - it's not cheap but it won't screw the seals in the rack. About 18 quid a bottle iirc.
Post 795813 by Harvey on 2016-01-29 19:09:38
Nice to see a bit of TLC mate , hope you can get it done without hitting any problems. :smile:
Post 795814 by M-R-P on 2016-01-29 19:11:37
Off round a mate's place in a bit. He's got a much bigger garage than me :)
After I fit his led headlights, he'll be handing me spanners while I work on the sweed.
Post 795815 by M-R-P on 2016-01-29 19:12:54
[QUOTE=kmb;795790]Think I can manage that, will check on Amazon for the correct PAS fluid and maybe do next week when UK side :)[/QUOTE]
[QUOTE=M-R-P;795791]Use genuine Volvo stuff - it's not cheap but it won't screw the seals in the rack. About 18 quid a bottle iirc.[/QUOTE]
Correction - just picked up 2 bottles from local dealer and it totalled 33.12 with vat.
Post 795988 by M-R-P on 2016-02-01 22:28:48
So far I managed the power steering fluid flush, brake/clutch system flush, the handbrake refresh and one of the rear droplinks.
I'm determined to get it done by the end of the month but time really is at a premium this month.
I can't do the oil/filter change until the new core for the 19t arrives so the next job will be track rods and tranny flush.
Updates to follow.
Post 796038 by M-R-P on 2016-02-02 20:02:57
Managed to do the tranny flush today. What came out was worrying. Smelly, dark, sparkly oil that's only been in there since I had the clutch done - about 20k.
There's a good chance it had full synth in it.
Post 796336 by Dave_T5 on 2016-02-10 00:08:36
[QUOTE=M-R-P;795988]So far I managed the power steering fluid flush, brake/clutch system flush, the handbrake refresh and one of the rear droplinks.
Updates to follow.[/QUOTE]
Sounds like you've been busy!
Give me a shout if need any help with the track rods / checking the geometry after, might be able to lend a hand if time allows. (Have 4 wheel alignment kit at work, only down the road)
Dave
Post 796347 by M-R-P on 2016-02-10 11:50:07
Awesome dave - thanks.
I'll pm you shortly.
Post 796348 by M-R-P on 2016-02-10 11:53:30
Well, as you've probably seen, the core is in, the oil and filter has been changed (cheap oil for now, good stuff going in soon) and all is well.
Track rod tonight and hopefully the other rear droplink.
Feeling pretty pleased :)
