Boost
Post 795840 by kevinking2020 on 2016-01-30 14:55:53
Fitted a boost gauge today and not bad all for around £20.00 but I'm only boosting to about 13psi and sometimes spikes 15/16psi the car was remapped from previous owner about 7 years ago but isn't 13psi standard boost? What should a remap be boosting to? Some photos: Image Image Image Image I'm still deciding wether to keep it in that location...
Post 796099 by LeeT5 on 2016-02-04 01:47:33
[QUOTE=kevinking2020;795840]Fitted a boost gauge today and not bad all for around £20.00 but I'm only boosting to about 13psi and sometimes spikes 15/16psi the car was remapped from previous owner about 7 years ago but isn't 13psi standard boost? What should a remap be boosting to? [/QUOTE] On ME7.1, Boost is Torque dependent. Also, 'Boost request' and actual boost can be two different things. Meaning boost request, although mapped, is dependent on lots of different things including Throttle position, Ambient air temp, Atmospheric pressure, Torque request - in which ever given gear at whatever given speed, 4C setting etc etc. Basically, there is no specific boost reading that you should be seeing. It's variable! The figures you are seeing would appear to be completely normal to me and nothing to worry about. ;) Just because the car was mapped, doesn't mean that the 'Boost request' and 'Torque request' parameters were altered in the MAP. That's why when ppl pull fuses 6 and 23 to rest the ECM, this forces the Module to 'relearn' driving style. It adapts very quickly and doesn't take long for adaptations to be set and stored. You'll often see higher boost readings initially on your gauge that, after a reset, seem to decrease. This is totally normal. [QUOTE=kevinking2020;795840] Image [/QUOTE] ....and sort that earth out aswell!!! That's a bodge, if ever I saw one. You need a proper Eyelet not bear wire stuffed under a bolt :nono:
Post 796106 by jamesy12345 on 2016-02-04 07:51:52
The below site says standard (max) boost is 14.7 psi/just over 1 bar http://media.caranddriver.com/files/volvo-s60r-awd.pdf
Post 796108 by LeeT5 on 2016-02-04 08:41:40
[QUOTE=jamesy12345;796106]The below site says standard (max) boost is 14.7 psi/just over 1 bar http://media.caranddriver.com/files/volvo-s60r-awd.pdf[/QUOTE] It also says max speed 146mph. In the UK it's 155mph. I don't pay too much attention to American info from press magazines. They're often wrong and also cars that ship to the US are often altered to suit the US market.
Post 796109 by LeeT5 on 2016-02-04 08:48:01
1.1 bar (16 psi) (Technical training course TU1-0819 29 May 2003 V2 )
Post 796114 by jamesy12345 on 2016-02-04 10:55:49
[QUOTE=LeeT5;796109]1.1 bar (16 psi) (Technical training course TU1-0819 29 May 2003 V2 )[/QUOTE] yes as per post #17 below... http://forums.swedespeed.com/showthread.php?13923-How-much-boost-does-the-V70R-S60R-run-stock That thread mentions that 14.7 is max sustained boost & 16 psi is max peak boost May be an indicator that the OP's car is not mapped
Post 796116 by M-R-P on 2016-02-04 12:17:59
Or its a crap gauge lol
Post 796117 by volvokid on 2016-02-04 12:36:13
It would work fine in a T5 Martin ��
Post 796118 by M-R-P on 2016-02-04 12:37:39
Nob. :finger:
Post 796119 by LeeT5 on 2016-02-04 12:49:27
Kevin, are you 100% your car has been mapped? If you're not, then I do know a good mapper, in Maidstone, that will be able to read your ECM files and compare them to a stock tune. That will establish 100% if it is mapped or not. On a side note, I gotta say that I'm not a big fan of gauges of any type, stuck on the dash with a cheap plastic mount. They just look out of place, like they're not meant to be there. Also, wires showing etc....not a good install my friend. Alas, I'm not here to poke at your handy work, but if you're happy with it? You could instead mount the gauge (being a 52mm type) in the air vent!! This will look cleaner and will hide all the wires. Whilst you're there, you must clean the dust off your steering column! ;)
Post 796120 by LeeT5 on 2016-02-04 12:49:58
:hihi: [QUOTE=M-R-P;796118]Nob. :finger:[/QUOTE]
Post 796122 by jamesy12345 on 2016-02-04 13:03:10
[QUOTE=LeeT5;796119]...On a side note, I gotta say that I'm not a big fan of gauges of any type, stuck on the dash with a cheap plastic mount. They just look out of place, like they're not meant to be there. Also, wires showing etc....not a good install my friend. Alas, I'm not here to poke at your handy work, but if you're happy with it? You could instead mount the gauge (being a 52mm type) in the air vent!! This will look cleaner and will hide all the wires...[/QUOTE] they can be useful for a bit of fault finding, this one looks OK too... [ATTACH=CONFIG]30226[/ATTACH]
Post 796123 by M-R-P on 2016-02-04 13:20:43
Mines fibre glassed into the speedo cowl.
Post 796125 by kevinking2020 on 2016-02-04 16:03:24
[QUOTE=LeeT5;796119]Kevin, are you 100% your car has been mapped? If you're not, then I do know a good mapper, in Maidstone, that will be able to read your ECM files and compare them to a stock tune. That will establish 100% if it is mapped or not. On a side note, I gotta say that I'm not a big fan of gauges of any type, stuck on the dash with a cheap plastic mount. They just look out of place, like they're not meant to be there. Also, wires showing etc....not a good install my friend. Alas, I'm not here to poke at your handy work, but if you're happy with it? You could instead mount the gauge (being a 52mm type) in the air vent!! This will look cleaner and will hide all the wires. Whilst you're there, you must clean the dust off your steering column! ;)[/QUOTE] I've got an invoice that the car was remapped like 7 years ago by the original owner. The previous owner I brought it from phoned the company and they said it was mapped to 340bhp etc... I had my car serviced last year at SW Autos and the owner Stuart said the car has been remapped. The car needs mapping again due to having 3" downpipe, decat etc.. I've been speaking to JR Tuning in sittingbourne but going to wait until I've got FMIC. I'm not happy with the location of gauge as it's showing all wires and is just temporary so I can see what boost I'm running. I'll be looking into getting a pillar gauge pod or door pod. haha the car needs a good clean inside which is on my list to do.
Post 796126 by LeeT5 on 2016-02-04 16:34:01
I know Stuart very well, known him years! You won't need a remap, the car will just adapt to the new mods. Here's my boost gauge: day and night pictures included. http://www.vpcuk.org/forums/showthread.php?43376-Fitting-an-IPD-boost-guage-and-door-pod-(P2)
Post 796132 by jamesy12345 on 2016-02-04 18:35:01
[QUOTE=LeeT5;796126]I know Stuart very well, known him years! You won't need a remap, the car will just adapt to the new mods. Here's my boost gauge: day and night pictures included. http://www.vpcuk.org/forums/showthread.php?43376-Fitting-an-IPD-boost-guage-and-door-pod-(P2)[/QUOTE] I didn't realise you had yours mounted on the door, Lee, looks good
