Post 796286 by sanj on 2016-02-08 20:36:25
Hi, Long shot.... but any one know of the part number for the oil sump to gear box bolts (x2) on a V70 2006 T5. Volvo parts department cant find them on their system. Thanks Sanj
I'm guessing (from taking mine apart) that they're probably the same as the upper bolts for which there are two part numbers listed (different lengths). Have you any originals to compare? If so here are the part numbers for the different lengths: M10x40mm bolt - 982819 M10x70mm bolt - 982825 The catalog says there are five of each bolt used so if you have 10 holes altogether then it is probably one of these bolts. Hope this helps
Hi Dave, Thanks for replying. 982819 looks like the part but I will check when I'm back home. It's only two bolts which are screwed horizontally from the oil pan to the gear box which I have removed. I will try and upload a picture. thanks again Sanjay
