Post 796627 by burgess on 2016-02-15 03:04:38
Had my C70 given a full service including software update at the local Main dealer in..
Llanfairpwllgwyngyllgogerychwyrndrobwllllantysiliogogogoch.
Was given an advisory front OS caliper needs replacing. Any recommendations as to where to obtain a standard caliper:
#1 From a good a breaker's yard, via the net,
#2 Reconditioned OEM
#3 After market new unit
I've looked at PFS, and casparts4less and ebay.
I'm not looking to upgrade just standard, leastwise for this year.
Burgess
Post 796635 by stribo on 2016-02-15 07:23:20
I got one from Eurocarparts, was only about £60 service exchange I.i.r.c.
Post 796712 by Wobbly Dave on 2016-02-16 16:37:49
I am in the process of swapping mine off for a BBK so you can have them for 30 quid & I will include the goodridge lines.
Post 796812 by burgess on 2016-02-18 15:08:35
[QUOTE=Wobbly Dave;796712]I am in the process of swapping mine off for a BBK so you can have them for 30 quid & I will include the goodridge lines.[/QUOTE]
Thanks for the offer Dave sounds good, are the disks OK?
Can you PM me with your phone number and post code. The front off-side beginning to squeal as the disk heats up. So need to inspect, if I can fettle that for now, I might try coming over the rim peaks are white so may need to find the survival kit. How far over the boarder are you?
Burgess
Post 796888 by Wobbly Dave on 2016-02-19 20:33:34
Telford. I have anti squeal shims that you can fit and the DS2500 pads have loads of wear left.
