Post 796700 by cammiet on 2016-02-16 13:27:42
I know this is already a highly debated subject but as I'm looking to buy a V70R at some point this year , I'm trying to justify the usual maintenance issues and running cost that come with it. Do you guys know a preferred supplier that provides us with a discount on the Monroe oem 4c complete suspension units?
Cheers
Cam
Post 796701 by abdul on 2016-02-16 13:48:27
i presume they are not cheap
Post 796705 by jamesy12345 on 2016-02-16 15:05:30
[QUOTE=abdul;796701]i presume they are not cheap[/QUOTE]
I'll start off - 300 quid a corner
http://shocksandmore.co.uk/info-monroe-what-fits-my-car?make=Volvo&model=S60&engine=2.5000&year=2004&search=Part+Number
//edit
a bit cheaper 510 quid for a front pair & 340 for the rear
http://www.bestpartstore.co.uk/7435947
http://www.bestpartstore.co.uk/7435943
Site looks a bit dodgy though...!
Post 796706 by Yosser on 2016-02-16 15:48:56
I'm pretty sure they can be had for about half that, Monroe sold via Amazon I think.
Post 796719 by cammiet on 2016-02-16 19:43:20
Thanks lads. Seems like they wouldn't be that difficult to fit myself and would just go to Volvomax in Glasgow to get he software installed and set up. Thanks for the info.
Post 796721 by jamesy12345 on 2016-02-16 21:36:26
[QUOTE=cammiet;796719]Thanks lads. Seems like they wouldn't be that difficult to fit myself and would just go to Volvomax in Glasgow to get he software installed and set up. Thanks for the info.[/QUOTE]
came across this while looking for other sellers - some 4C bumpf
https://www.volvoclub.org.uk/tech/2004r/R5-Four-C.pdf
Post 796724 by LeeT5 on 2016-02-16 22:06:23
The fronts are cheap at £161 a corner but the rears seem to have shot up. They retail at £530 ea but an be bought for £378 a corner.
Post 796730 by jamesy12345 on 2016-02-17 07:04:13
[QUOTE=LeeT5;796724]The fronts are cheap at £161 a corner but the rears seem to have shot up. They retail at £530 ea but an be bought for £378 a corner.[/QUOTE]
I posted this above, Lee, rears (C1501) seem to be available for 290 quid a pair
[QUOTE=jamesy12345;796707]Rears 290 quid a pair
http://www.amazon.co.uk/Monroe-C1501-C-E-S-2-pieces/dp/B00AJUDP2Q
...[/QUOTE]
Post 796734 by LeeT5 on 2016-02-17 09:55:08
[QUOTE=jamesy12345;796730]I posted this above, Lee, rears (C1501) seem to be available for 290 quid a pair[/QUOTE]
Bargain then!
Post 796737 by Jimmie on 2016-02-17 10:20:07
They might be a bargain but what happens if there is a problem (electrical) with them before the warranty is out.
I had that problem but the factors that I deal with ordered in a replacement set before the ones on the car were removed .
I'll bet they'll need them back to check for any problems before they will issue replacements.
There was a long period that nobody had them in stock .
Post 796738 by jamesy12345 on 2016-02-17 10:27:58
[QUOTE=Jimmie;796737]They might be a bargain but what happens if there is a problem (electrical) with them before the warranty is out.
There was a long period that nobody had them in stock .[/QUOTE]
fair comment but the price difference makes it tempting - 378 quid vs 145 & you are supposed to do them in pairs AFAIK. Assuming they are the real items that is!!
Post 796743 by LeeT5 on 2016-02-17 10:40:44
[QUOTE=jamesy12345;796738]fair comment but the price difference makes it tempting - 378 quid vs 145 & you are supposed to do them in pairs AFAIK. Assuming they are the real items that is!![/QUOTE]
Shock absorbers are alway done in pairs, regardless of the car.
Any garage that doesn't should be strongly avoided. You wouldn't change only one brake disc....
Think yourself lucky it's not a 2010> RS6 as they are almost £2000 a corner at Audi!
Post 796744 by jamesy12345 on 2016-02-17 10:48:18
[QUOTE=LeeT5;796743]Shock absorbers are alway done in pairs, regardless of the car.
Think yourself lucky it's not a 2010> RS6 as they are almost £2000 a corner at Audi![/QUOTE]
I had a walk around an 'approved used' C5 RS6 once in an Audi dealership, ran away when I saw the ceramic discs....
Post 796779 by Dream3r on 2016-02-18 00:36:13
I got the fronts this way, zero issues, bargain.
Post 796780 by Dream3r on 2016-02-18 00:37:32
Careful as iirc V70R rears are different. Not sure my Volvo R knowledge is fading fast!
