2.5 TDi (AEL) Crank TDC?
Post 797407 by petrolh34d on 2016-02-28 00:14:38
I can't seem to find the TDC mark anywhere for the crank on this engine. Been trawling forums for answers, but to no avail. Any ideas how I can set the crank to TDC?
Post 797417 by martin_r_smith on 2016-02-28 10:08:00
Replied on voc mate.
Post 798685 by petrolh34d on 2016-03-27 15:43:21
Thanks Martin! Twas indeed on the bottom of the gearbox. :slap: Incidentally, I had a hell of a job finding any information about the correct locking tool for the crank, so I made my own out of a bit of pipe, and the pulley of my old water pump. I'm sure there's other ways around it, but this worked a treat for me, at minimal expense. Here's some images which hopefully give you the gist of how it worked. [ATTACH=CONFIG]30440[/ATTACH][ATTACH=CONFIG]30442[/ATTACH][ATTACH=CONFIG]30441[/ATTACH][ATTACH=CONFIG]30443[/ATTACH][ATTACH=CONFIG]30444[/ATTACH]
Post 798695 by martin_r_smith on 2016-03-27 18:49:58
I just use a the flat and of a crow bar in the teeth of the flywheel through the inspection hole, works a charm. That crank bolt has to be done mighty tight though doesn't it! Did you use a new bolt too?
Post 798699 by petrolh34d on 2016-03-27 20:02:24
That's a handy way around it also Martin. Yeah, my timing kit came with all the torque settings for the bolts. It said to torque the crank bolt to 160Nm, and then another 180 degree's. I accidentally torqued it to 180Nm, and couldn't get it to move another millimetre afterwards, even though I was basically swinging off a big bar! (I reckon it's not going anywhere though lol) I didn't use a new bolt, no. Is this highly recommended?
Post 798701 by martin_r_smith on 2016-03-27 20:21:28
Volvo do say replace it but not many do.
