Maxspeeding rods
Post 797820 by nottsgreent5 on 2016-03-08 20:15:22
Evening all maxspeeding have rods for £210 inc p&p at the moment im about to buy a set but i thought id ask 1st to see if anyone has these fitted ie. Are there any fitting issues etc they seem very good value
Post 797821 by Nealevo on 2016-03-08 20:30:47
eBay number 281934113559
Post 797822 by claymore on 2016-03-08 21:00:04
just make sure you fit the big end bearings properly, or you join the long list of people with spun bearings :( (this has nothing to do with these rods, just a general observation)
Post 797826 by MoleT-5R on 2016-03-08 22:17:28
[QUOTE=claymore;797822]just make sure you fit the big end bearings properly, or you join the long list of people with spun bearings :( (this has nothing to do with these rods, just a general observation)[/QUOTE] Unfortunately know of a couple now the have spun big end bearings
Post 797829 by t5 pete on 2016-03-08 23:37:25
The main problem is in our engines they have no location tabs so a lot of people just fit them how ever on another note I would also check your crank for wear and get the correct size bearing
Post 797830 by Tim Williams on 2016-03-09 00:28:13
They are down to £200 delivered now. They should fit but check them carefully as I've had them before where they are too wide to clear the bottom of the bore and too wide to fit in the piston. If you number each rod and bearing cap on just one side BEFORE removing the caps you may be less likely to screw up as badly.
Post 797845 by Dangerous Dave on 2016-03-09 11:47:57
I have them in the engine I've just fitted in the Green AWD. Fitted genuine volvo bearings in them and they seem to have fitted ok and starts ok. Time will tell once I get it MOTed and start driving it :worried:
Post 797858 by nottsgreent5 on 2016-03-09 18:03:55
Thanks for all the advice i will keep you all updated and more than likley ask a few more questions when the build gets underway
