Post 798454 by Wheelspinwardrobe on 2016-03-21 18:29:51
Hi Everyone Options / price for aftermarket engine management AUTOMATIC T5??? Is there any options (thinking Auto ECU compatibility etc) Any help appreciated.. Thanks Phill
It depends what you need to run with it. What year ect is it?
Hay Tim, Tim as in Don's Kalmar Union's mate by any chance ??? If so we spoke a few months back....
[QUOTE=Tim Williams;798456]It depends what you need to run with it. What year ect is it?[/QUOTE] Its a 1994 estate
The main question is why do you think you need one
I got an adaptronic kit & loom made up for about 700 quid for a different car but that said why not use a 'known' map on the standard ecu - on my T5 auto (m4.4) I had a TME map that worked fine although the only mods to it was the exhaust
You should be able to use a Motec but as pointed out its a waste of time and money, you already have a far better system on the car. The cost and time to transport the car is far less than messing around with something that WILL be a pain. If transporting the car is too much you would be far better off learning about your engine and mapping the the ECU you have. I remember talking to you and your mechanic at length.
