No Cruise and any local code reading people?
Post 799140 by Baj on 2016-04-05 11:23:52
For a few years I have had no cruise control. The 'Cruise' message appears on the dash but it wont set or hold any speeds. The only error I have had on the dash has been Alarm service which I can see effecting it (the rechargable battery in the alarm is dying) Unrelated, I have an antiskid error just start showing too. I am guessing it is just a wheel sensor but if there is anyone fairly close by that has the ability to properly read codes so I can know which one is wonky, that would be awesome. Let me know your preferred beer. My OBD reader tells me nothing of interest. I am fixing up all the little issues that have built up over the years :D
Post 799141 by Orca2 on 2016-04-05 11:30:41
Check your front abs rings for cracks or missing teeth or mud/rust. They are a very common cause of cruise not working.
Post 799144 by Baj on 2016-04-05 12:03:54
Will do, ta
Post 799145 by ExternalError on 2016-04-05 12:27:49
also get the codes read as the clutch position sensor on the pedal is a common point of failure for cruise control it wont show as an error on the dash but will show as a clutch position sensor high reading when you read the codes
Post 799148 by M-R-P on 2016-04-05 13:08:47
Usually, you can clear the clutch position sensor code and it'll behave (mine got cleared 3 years ago and still working) but it's often better to replace it. Not expensive and a simple swap.
