Post 800591 by bonnietiler on 2016-05-05 15:02:33
Hi Guys, I've had no mileometer for a while so I just replaced the mileometer wheel and hey..it works.. no problems except..I have no Fuel or temp gauge the turbo works fine all the others work...any ideas or do I just pull it all down again..Humph
Post 800593 by Tim Williams on 2016-05-05 18:36:09
Most likely one of the connectors isn't on all the way.
Post 800615 by bonnietiler on 2016-05-06 12:38:01
So....what I did was...remove everything and put it all back again...worked fine weird??
Actually, when you've done it its not such a bad job, I could get the top dash off in an hour now and although a little fiddly the odometer repair is pretty easy as well
Post 805978 by Mark F on 2016-10-06 14:57:40
Hi Bonnie,
Where did you order your cogs from? I'm a moron, and fitted a cog without considering that it was going to record KM rather than miles.....!
you'll have used a UK company I guess?
Mark
