Engine System Requires a Service
Post 801230 by patch234 on 2016-05-23 10:40:00
Hi all, I keep getting the above message - intermittent - on my C30 2.5 T5. Comes and goes like sunny days in the UK! Any advice?
Post 801419 by S40kieran on 2016-05-26 19:50:43
I had this yesterday after cleaning my maf sensor it just dissapeard on mine. Nothing to worry about apparently. Thought at first I pulled something important out, rechecked it all couldn't see anything so glad it dissapeared though
Post 801421 by Harvey on 2016-05-26 20:31:31
Get the codes off the car.. don't guess.
Post 803143 by ton246 on 2016-07-17 10:40:17
I have this message, although I service it myself. Any ideas how to remove the message ? Tried following the one on the US forum but didn't work. Cheers
Post 803170 by antonys60r on 2016-07-18 08:58:43
[QUOTE=ton246;803143]I have this message, although I service it myself. Any ideas how to remove the message ? Tried following the one on the US forum but didn't work. Cheers[/QUOTE] You won't be able to , that message means there is a fault code in the ecu. You need vida to diagnose it correctly. Regular service required is a rountine service message that you can clear yourself.
Post 822764 by james on 2024-01-01 01:43:04
Hi I have the engine system service urgent message code 020, any ideas anybody? I’ve noticed the fan is not working could this be the issue? Got it booked in on Tuesday for a diagnostic was wondering if anyone could help or have any suggestions thanks in advance
Post 822765 by Dangerous Dave on 2024-01-01 19:21:14
Yeah a diagnostic will be a better bet, trying to get info from just a display code is not the best.
