V70 r maf?
Post 802458 by Dannyboy7 on 2016-06-24 22:48:09
Cars been driving well and went to start it this morning before going to work and it started and cut out about 20 secs on three attempts with the Mel light and limp mode light coming on. Have unplugged the lead to the maf and it runs without cutting out. I have bought some contact cleaner and cleaned the maf and will see what happens tmrw. Any thoughts welcomed. Dan
Post 802460 by Dannyboy7 on 2016-06-25 08:59:02
Maf cleaned some difference now but I need a maf sensor where's the best place to get one of these its a1997 v70 r auto, thanks Dan
Post 802462 by LeeT5 on 2016-06-25 10:45:28
On the side of your MAF there is a part number. It should say Bosch, then a direction of air flow arrow, then a long part number. What's the number?
Post 802485 by Dannyboy7 on 2016-06-25 23:27:41
Hi lee just got in from work I'll check in the morning and post details ta. Dan
Post 802489 by Dannyboy7 on 2016-06-26 09:23:51
Good morning the number is 0280 217 107, there's a number underneath that which reads 1275 749. Many thanks Dan
Post 802491 by Dangerous Dave on 2016-06-26 11:03:12
Used one on ebay: http://www.ebay.co.uk/itm/Volvo-V70-S70-C70-T5-Genuine-Bosch-MAF-Sensor-1275749-/400960154111?fits=Model%3AV70&hash=item5d5b1669ff:g:-ywAAOSwjVVVqpo- Genuine Bosch from carparts4less (plus £15 off if you enter code CP15LESS): http://www.carparts4less.co.uk/cp4l/c/Volvo_V70_2.3_1997/p/car-parts/engine-parts/fuel-and-engine-management/engine-management-sensor/?434660280&1&836ecee167711fc3edad07bc4b49f7f5c46504d6&000009 Interesting that there are different part numbers for the MAFs for the same engines..
Post 802492 by Dannyboy7 on 2016-06-26 11:45:22
Wow thanks for your help guys
Post 802497 by foammanmark on 2016-06-26 15:07:22
I bought the CRC MAF cleaner for my p1 V70 R but would contact cleaner basically have done the same? I keep getting the P0172 rich running code, but after the last MAF sensor clean it didn't reappear for 700-800 miles, which is the longest that it's gone. I'm now replacing lots of vac hose in case I have a leak somewhere as well.
Post 802509 by Dannyboy7 on 2016-06-26 22:00:44
I cleaned it with contact cleaner and it did improve it slightly but it still cuts out when maf plugged in. Funny thing is the day before there was no real symptons apart from the slight hunting and that was minimal and sometimes.
Post 802555 by LeeT5 on 2016-06-28 00:21:58
I wouldn't buy a second had MAF, else you'll be in the same boat as you are now in a week or two. They cost approx. £300 inc vat from Volvo (without discounts). BuycarpartsUK don't have any MAFs in stock, so the only place I would buy from would be... http://www.autodoc.co.uk/bosch/1150490?grmk=1&gclid=CIjA7Jmryc0CFRUW0woduFoFhg You also get a 2 year warranty :B_thumb: This will save you about £50 instead of buying from those cheesy t wat s at ECP's! (Don't they all just look and sound like bloody Estate agents!!! "Buy, buy...Sell, sell!!!...") All the ones on Ebay around the £24-£60 mark, claiming to be brand new! BS. They are cheap Chinese rubbish and not genuine Bosch, Avoid!
Post 802607 by Dannyboy7 on 2016-06-28 21:08:38
Thanks for the info will get a Bosch
Post 802619 by M-R-P on 2016-06-29 00:15:35
Contact cleaner tends to leave a film on the sensor, brake cleaner then a wash in clean water works for me. As far as I can tell, my car is still on it's original maf (no mention of a change in the plod service history) and it's approaching 223000 miles. I clean it when I change the filter. (sometimes)
