Post 804542 by rise94 on 2016-08-27 10:38:55
Question for owners of V70R AWD (240/250 / 265cv)
Could you give me the original height of your Volvo on the front and rear trains between the ground and the wing pass please?
Or between the wing and passing the center of the rim.
I need to adjust these values to my KW V2 kit and respect the plate of the car.
In advance thank you.
Post 804551 by MoleT-5R on 2016-08-27 19:25:19
[QUOTE=rise94;804542]Question for owners of V70R AWD (240/250 / 265cv)
In advance thank you.[/QUOTE]
Did you forget to measure it before fitting them.? I can measure my p1 ph3 awd for you, but it will be Sunday night at the earliest as I am currently swanning around Northamptonshire in the Gul for the touring car racing at Rockingham
Post 804611 by rise94 on 2016-08-29 10:02:11
[QUOTE=MoleT-5R;804551]Did you forget to measure it before fitting them.? I can measure my p1 ph3 awd for you, but it will be Sunday night at the earliest as I am currently swanning around Northamptonshire in the Gul for the touring car racing at Rockingham[/QUOTE]
Hi,
Yes I forgot to measure before installation. It is difficult to find the original height on the internet there ...
I do not know if we can get this information in VIDA?
There is no hurry for measurement. When I have the origins of heights I could adjust my KW kit V2.
Thanks in advance .:B_thumb:
Yann
Post 804748 by MoleT-5R on 2016-09-02 09:47:57
[QUOTE=rise94;804611]Hi,
Yann[/QUOTE]
Sorry for the delay, but I had let this slip my mind, but I have been and measured and she sits at 25"s from ground to bottom edge of the centre of the wheel arch, which is also the same measurement as both of my T-5R's saloon and estate, must be a P80 thing, hope that helps
Post 804753 by LeeT5 on 2016-09-02 10:24:27
[QUOTE=MoleT-5R;804748]Sorry for the delay, but I had let this slip my mind, but I have been and measured and she sits at 25"s from ground to bottom edge of the centre of the wheel arch, which is also the same measurement as both of my T-5R's saloon and estate, must be a P80 thing, hope that helps[/QUOTE]
Aren't you meant to measure from the center of the wheel to the wheel arch?
According to VIDA that's how you do it.
Post 804816 by MoleT-5R on 2016-09-03 18:19:05
[QUOTE=LeeT5;804753]Aren't you meant to measure from the center of the wheel to the wheel arch?
According to VIDA that's how you do it.[/QUOTE]
Thanks Lee you learn something new everyday, so that seems to make it 325mm in that case
