Post 804735 by craigoodwood on 2016-09-01 20:29:05
does any body know the internal diameter of the oil cooler hoses that go into the radiator?
an with regards to fitting an 8 row cooler what height it should be whether it should be higher than the sump, lower than the sump or the same.....
Post 804737 by Tim Williams on 2016-09-01 21:09:31
An 8 row will in most cases lower your oil pressure by about 0.5 Bar. The standard in rad one works fine for road or track as long as the revs are kept under 7400RPM.
Post 804746 by MoleT-5R on 2016-09-02 09:21:34
I plan on fitting mine down where the carbon canister is and use the fog light hole for airflow or a duct across from the side of the intercooler, as for the pipe internal diameter it's 3/8" as far as I'm aware.
Post 804773 by Tim Williams on 2016-09-02 18:17:47
Don't forget to check your oil pressure if fitting a cooler that will lower the pressure.
Post 804784 by craigoodwood on 2016-09-02 20:46:21
ah good advice, its only a thought really as my radiator has burst in the heat, i have a good rad with no cooler and acces to external coolers so was curious ;)
Post 804831 by JT on 2016-09-03 20:36:27
[QUOTE=MoleT-5R;804815]Nice touch JT, hope you remembered to put the filter back before firing it up though...;)[/QUOTE]
very good! lol
my filter is remote. :B_thumb:
Post 804834 by MoleT-5R on 2016-09-03 21:15:59
what blanks the original filter mount seen in the bottom of the picture JT ??
Post 804884 by JT on 2016-09-05 12:19:41
[QUOTE=MoleT-5R;804834]what blanks the original filter mount seen in the bottom of the picture JT ??
[/QUOTE]
Just pulling your leg mate. :)
The oil filter goes in the standard position and would probably explain why it still works, unlike anything else on the car. lol
Post 804890 by martin_r_smith on 2016-09-05 15:26:09
I removed my oil/water heat exchanger in favour of a mocal thermostatic plate and cooler up front of the intercooler (pictures in my project thread somewhere). As I have a oil cooled turbo the oil was getting very hot but now stays around 90-95* and my pressure has increased slightly (+0.1-0.2bar) rather than decrease.
Post 804957 by MoleT-5R on 2016-09-07 09:04:14
[QUOTE=JT;804884]Just pulling your leg mate. :)
The oil filter goes in the standard position and would probably explain why it still works, unlike anything else on the car. lol[/QUOTE]
I see, when you meant "remote oil filter" it is a bit like your remote front wheels... no longer attached to the car...lol
Post 804958 by MoleT-5R on 2016-09-07 09:19:38
[QUOTE=martin_r_smith;804901]
[/QUOTE]
I'd thought about the central position for my cooler but I'm favouring mounting it in the area of the carbon canister (now deleted) as I don't want to place a heat source in front of the I.C. as the car is only doing very short sprints up a dragstrip or hillclimb for the majority of my sport thus it would be quite hot in my eyes with all the standing time and not much cooling is going to happen in 14 seconds and the run is then over, obviously the oil will be cooling nicely on the run back to the paddock after the stresses of the previous few seconds, but I need and instant chill to the cooler so leaving it with a clear cool air passage is my way forward, if it where for circuit use then I'd probably go for the central position.
Post 804965 by martin_r_smith on 2016-09-07 09:45:21
[QUOTE=MoleT-5R;804958]I'd thought about the central position for my cooler but I'm favouring mounting it in the area of the carbon canister (now deleted) as I don't want to place a heat source in front of the I.C. as the car is only doing very short sprints up a dragstrip or hillclimb for the majority of my sport thus it would be quite hot in my eyes with all the standing time and not much cooling is going to happen in 14 seconds and the run is then over, obviously the oil will be cooling nicely on the run back to the paddock after the stresses of the previous few seconds, but I need and instant chill to the cooler so leaving it with a clear cool air passage is my way forward, if it where for circuit use then I'd probably go for the central position.[/QUOTE]
I understand that and i too was a little worried about placement up front, however after monitoring inlet temps pre and post i/c i found no difference with it fitted upfront. I can imagine that would be different after sitting in the staging lanes for a while though.
Post 804968 by claymore on 2016-09-07 09:52:39
You're all wrong, the oil cooler should be on the roof :)
Post 804969 by Doingitsideways on 2016-09-07 10:03:17
[QUOTE=claymore;804968]You're all wrong, the oil cooler should be on the roof :)
[/QUOTE]
Does the Vauxhall sticker help with ACTs too? ;)
Post 804970 by MoleT-5R on 2016-09-07 10:04:18
[/QUOTE]
we all know you have to be different...lol
[QUOTE=martin_r_smith;804965]I understand that and i too was a little worried about placement up front, however after monitoring inlet temps pre and post i/c i found no difference with it fitted upfront. I can imagine that would be different after sitting in the staging lanes for a while though.[/QUOTE]
interesting to hear this, how much difference do you notice if the car is hot and stood for a while to when you start moving again and how quick does it drop Martin..?
