Volvo C70 Cabrio Code readers
Post 804804 by burgess on 2016-09-03 14:37:47
Volvo C70 Cabrio Code readers to diagnose soft-top problems. Is there any members who have, or know of such a code reader, if so can one be used to operate the roof if re-calibration is required.
Post 804828 by Tim Williams on 2016-09-03 20:12:23
I was discussing this with Kings Motors the other week, the only Volvo thing that will work with your roof is a Volvo System Tester. A VCT 2000 or Dice won't do it.
Post 804849 by burgess on 2016-09-03 22:46:08
[QUOTE=Tim Williams;804828]I was discussing this with Kings Motors the other week, the only Volvo thing that will work with your roof is a Volvo System Tester. A VCT 2000 or Dice won't do it.[/QUOTE] Thanks Tim, I'm hoping re-calibration isn't required. I'll soon be having a scan done with VIDA and DiCE, hopefully it will reveal the nature of the problem. I can then do the mechanical checks and any hardware micro-switch or pot replacements then have local Volvo dealership to do re-calibrations if needed.
Post 805013 by burgess on 2016-09-08 04:02:18
[QUOTE=Tim Williams;804828]I was discussing this with Kings Motors the other week, the only Volvo thing that will work with your roof is a Volvo System Tester. A VCT 2000 or Dice won't do it.[/QUOTE] It would be good if there is someone who knows what protocol the Volvo System Tester uses?
Post 805099 by burgess on 2016-09-09 16:55:28
Ok, does anyone know if the ‘Volvo Scan Tool' is just Volvo jargon for VIDA/DiCE, or is it another piece of kit all together? If it is another piece of kit, does anyone know the Volvo part number?
Post 805194 by boycdon on 2016-09-12 10:14:24
hi,ive just replaced the complete roof on my c70 cab and after fitting it works perfectly with no re calibration ?
Post 805240 by burgess on 2016-09-13 12:05:45
[QUOTE=boycdon;805194]hi,ive just replaced the complete roof on my c70 cab and after fitting it works perfectly with no re calibration ?[/QUOTE] Was it working error free with the old roof.
Post 805282 by boycdon on 2016-09-13 20:35:28
[QUOTE=burgess;805240]Was it working error free with the old roof.[/QUOTE] hi,no there was a fault where i had the chime sounding to indicate that the cycle was not complete......replaced the entire roof and lid assembly ...and now works perfectly with no issues :biggrin:
Post 805325 by burgess on 2016-09-14 18:06:05
I've booked in for a diagnostic on Friday over at Tyn Lon Volvo dealership over in Llanfair PG, better known as llanfairpwllgwyngyllgogerychwyrndrobwllllantysiliogogogoch or as someone once said ‘somewhere in Wales' Tyn Lon have not long sine done a complete re-fit on a C70 roof so ought to have the tech know how and experience to identify the problems.
Post 805514 by burgess on 2016-09-18 12:29:29
System scanned on Friday, two thinks are now apparent the VIDA/DiCE can interrogate the CRM, but able to calibrate. unfortunately their VST is no-longer functional so not able to re-calibrate. Dose anyone know of 1# a dealership that can do re-calibration? 2# anyone that posses a VST?
