Assuming my Cat Is a DUD now what would the team recommend?
Post 805226 by bonnietiler on 2016-09-12 23:38:52
It appears that the Cat has bitten the dust. It seems to be a race cat welded into the original pipes Joolz would know? It also seems to have collapsed, lots of rattling and rumbling together with a Lambda light. So..if that is the case I have a TME cat back fitted what would you recommend..Standard..100 cell 200 cell new Lambda sensor? Do tell Cheers Bonnietiler
Post 805229 by Tim Williams on 2016-09-13 08:27:35
Jimka has a straight flange DP that's in good order. If fitting a sports cat I would fit a good one not an ebay special.
Post 805230 by Ettienne on 2016-09-13 08:35:15
I will have a Ferrita for sale at some point (same as Jims) and a few other shiney bits, just not immediately.
Post 805255 by The White Knight on 2016-09-13 14:32:22
Can I have first dibs on that Ferrita DP? PM sent Thanks, Sunny
