Post 806044 by Blackdog on 2016-10-09 14:35:47
Hi I have just acquired a 07 V70 2.4D SE Sport.
The auto function on the drivers window does not work correctly on closing. It goes all the way up and the drops back down again as of is triggering the finger sensor.
Is there a sequence that I need to do to reset the close cycle?
It works fine in manual mode.
Thanks in advance.
Post 806047 by The Flying Moose on 2016-10-09 15:45:37
I had the exact same issue with my 54 plate. It needed plugging into vidas and reprogrammed to make the window "learn". Where the top is.
Post 806049 by Yosser on 2016-10-09 16:22:29
I've never had this problem, but I believe it can be reset without vida;
http://forums.swedespeed.com/showthread.php?140864-how-to-do-power-window-calibration
Post 806051 by Blackdog on 2016-10-09 17:24:26
Thanks for the link Yosser.
Pulled the fuse during the auto cycle. Ignition off. Fuse refitted. And all is working as it should.
Post 806077 by Ettienne on 2016-10-10 20:58:51
I did the fuse way on the xc90 worked perfectly
