Post 806050 by bonnietiler on 2016-10-09 16:53:49
Hi guys just going through everything now I wonder if anybody can help with correct connections of the White Pipes that seem to go into a valve Front right
Just checking that this is connected correctly...er...what is it? Could it be blocked
Cheers
Post 806052 by leet5r on 2016-10-09 17:40:38
sure that goes to the incar boost gauge
Post 806053 by MoleT-5R on 2016-10-09 18:38:49
[QUOTE=bonnietiler;806050]Hi guys just going through everything now I wonder if anybody can help with correct connections of the White Pipes that seem to go into a valve Front right
Cheers
[/QUOTE]
As Lee has already said, the white pipe exiting the bottom of the picture is going to the dashboard boost gauge and the other white pipe runs to the fuel pressure regulator and the valve you mention that they are connected to is in fact known as the Vacuum Tree, hope this helps
