P1 T5 vs. R engine differences (ENGINE ONLY)
Post 806324 by Ayrshore on 2016-10-19 21:24:11
So, there's usually much discussion about the V70/S70R, but I'[m asking specifically about the engine only, and only the 2319cc engines. Aside from the turbos, are there any differences in the engines themselves? Thanks in advance.
Post 806328 by Tim Williams on 2016-10-19 21:42:53
The 2319cc engines in an R, be it 850, S70 or V70 are exactly the same as found in the T5 model of the same year. An 850 engine uses different pistons to an S/V70.
Post 806329 by Ayrshore on 2016-10-19 21:45:36
Excellent. Now I just need to find a nice manual V70R with a rattly engine, like the one I didn't bid on on eBay before I got this T5...
Post 806330 by Shinsplintz 101 on 2016-10-19 21:46:15
As Tim said :)
Post 806335 by Ettienne on 2016-10-19 23:07:59
850r / V70r p1 is meant to have treated rods, I believe to make them slightly stronger but this makes no different afaik.
Post 806365 by Wobbly Dave on 2016-10-20 23:57:59
Best block is probably the 83mm bore (B5244T2) - look through Shemtek's spares bin - https://www.facebook.com/shemtekautomotive/?fref=ts
Post 807049 by dionbullock on 2016-11-10 13:38:42
Did the later t5's (99' onwards) have VVT???
Post 807050 by Ettienne on 2016-11-10 14:18:20
[QUOTE=dionbullock;807049]Did the later t5's (99' onwards) have VVT???[/QUOTE] Yes exhaust can only iirc
Post 807051 by 960kg on 2016-11-10 14:46:51
[QUOTE=Ettienne;806335]850r / V70r p1 is meant to have treated rods, I believe to make them slightly stronger but this makes no different afaik.[/QUOTE] Just to help from my post years ago....lol The early B234T4 850r had a spluttered coating upper connecting rod bearing halves for extra strength. The B5234T3 which is in the `97 on p1 V70 T5 has the stronger rods which are exactly the same as the R ones and a lot stronger than the 850. The first engine to have these rods was the 1996 B234T5 850r/T5r This is why 850`s break rods easier than the V70...
Post 807052 by Ettienne on 2016-11-10 14:59:57
[QUOTE=960kg;807051]Just to help from my post years ago....lol The early B234T4 850r had a spluttered coating upper connecting rod bearing halves for extra strength. The B5234T3 which is in the `97 on p1 V70 T5 has the stronger rods which are exactly the same as the R ones and a lot stronger than the 850. The first engine to have these rods was the 1996 B234T5 850r/T5r This is why 850`s break rods easier than the V70...[/QUOTE] I knew they where on the 850r and then STD on the v70 t5, still obviously not as good as forged but everything helps I guess.
Post 807340 by Ayrshore on 2016-11-18 20:11:34
B5234T3 is the engine I have in the T5 I got for free, so I'm good - so far :)
